Can I connect these sensors through my RJ-45 CAT5/6 patch panels? Can I use those female to female CAT5 RJ-45 couplers to extend them?
AKCP AdministratorIntelligent Sensors, Support
No, we do not recommend you trying to connect any of our AKCP sensors including the temperature and dual temp humidity sensors though patch panels or using the RJ-45 couplers to extend them. You may find that this works, however it will be very inconsistent and this is due to the signal strength from the sensor to the base unit. The resistance of the extra connectors in a patch panel, or couplers is often enough to prevent the sensor from working.
AKCP AdministratorCan I connect these sensors through my RJ-45 CAT5/6 patch panels? Can I use those female to female CAT5 RJ-45 couplers to extend them?
