My securityProbe8-X20 has the 20 extra dry contacts, can I configure these as inputs and outputs?
AKCP AdministratorsecurityProbe Series, Support
You can generate an output (0VDC/5VDC) using a dry contact sensor on the both the securityProbes on an alarm state, however this is done using one of the 8 RJ-45 Intelligent sensor ports on these units and not the 20 extra dry contacts. The extra dry contacts on these devices are for input only
AKCP AdministratorMy securityProbe8-X20 has the 20 extra dry contacts, can I configure these as inputs and outputs?
