AKCP Announces The sensorProbe+1 Base Unit
															AKCP, the world’s oldest and largest supplier of networked wired and wireless sensor solutions has announced the sensorProbe1+ Monitoring Base Unit
AKCP has announced the release of their latest addition to the sensorProbe+ series. The sensorProbe1+ (SP1+) is a simple, yet powerful SNMP-enabled sensor device. Equipped with an intelligent sensor port, a dry contact input, a fixed length 5ft temperature sensor, and PoE as standard. The SP1+ runs the same software and user interface as the rest of the sensorProbe+ series. It features the same functionality with up to 80 virtual sensors (5 included for free), SNMPV3, IPV6, Radius, Tacacs, Modbus TCP/IP, MQTTS, and more.
The SP1+ comes with a 1-year subscription to the AKCPro Server Cloud. Up to 4 base units per company can be connected for free, for 12 months. Centralize the management and monitoring with custom desktops, graphing, 3D mapping, and alerts, of all your deployed AKCP base units.
Connect a wide range of AKCP intelligent sensors to the sensor port of the SP1+. AKCP has sensors for environmental, power, and security monitoring. A built-in temperature sensor on a 5ft cable is also included. AKCP has dedicated sensors for monitoring the data center such as cabinet thermal maps. From the single sensor port of the SP1+ it is possible to add the sensor splitter box to monitor the temperature top, middle, bottom, front, and rear of the rack, ∆T, front/rear humidity, and current consumption of the rack. This is a total of 12 sensors off a single port. Add a door contact sensor to the dry contact and you have a complete cabinet environmental, security, and power monitoring solution for a single rack.
Powered via PoE, or a 5V USB input, the SP1+ can also be powered by both utilizing the PoE as a redundant power source.
The AKCP sensorProbe1+ is available today from your nearest AKCP Dealer. Contact sa***@ak**.com for more details.
															AKCP sensorProbe1+
															AKCPro Server 3D heat maps with thermal map sensors
