AKCP Security Scan Report
AKCP security scan report
July 2025
Data Center Security
A data center contains the enterprise’s IT equipment, applications and critical data, so it’s essential to provide proper security systems and security policy.
The main concerns regarding a data center’s security problems are data loss (whether it’s because of human error or from external attack, or from natural disasters), data alteration, Denial of Service (DoS), identity theft, and theft of confidential information.
Hardware-wise, it starts with the physical security of a data center to prevent any physical damage and unauthorized access to the IT equipment storing critical data, including protection from natural disasters.
On the software side, having proper antivirus/antimalware solutions, up-to-date software products, proper backups, and conducting frequent security audits can significantly lessen the impact of a possible security breach.
In the Cost of a Data Breach Survey where 49 U.S. companies in 14 different industry sectors participated, the following was found:
  • The average cost of a security breach could reach $5.5 million
  • 39% of the companies say that negligence was the primary cause of their data breaches
  • Malicious and other criminal attacks have accounted for 37 percent of the total breaches
  • The effects of a data breach can have severe consequences on both the company managing the data center and on the customers whose data are copied
Security status of AKCP products
Log4j Status
In light of the recent Log4j vulnerability, we have specifically tested for this. We do not utilize Java in our products and this threat is not a concern for AKCP devices.
Below we provide the latest information on malware and vulnerabilities in our product line (updated monthly):
  • sensorProbe+ (SP+)
  • sensorProbe (SP)
  • WTG
  • securityProbe (SEC5)
  • AKCPro Server (APS)
Important Note: All customers must update to the latest available versions to get the latest security updates. We do not provide support for, and are not fixing security issues in older releases. This applies to all of our software (APS, SP+, SEC5 etc.).
Every firmware release undergoes strict security vulnerability testing, using commercially available security vulnerability testing software. This ensures that our products are running up-to-date firmware which is free from known cyber security issues and zero-day software vulnerabilities.
A typical vulnerability test runs between 30 minutes to 2 hours, depending on the network services and open ports available on a given product family. The security scan runs on a dedicated closed network. It consists of common vulnerable ports testing, penetration testing, SNMP, SSL and web application tests, compliance checks, and standard vulnerability tests.
The antivirus scan of AKCess Pro Server’s executables is performed with well-known antivirus engines, such as:
  • Avast
  • Avira
  • AVG
  • BitDefender
  • ClamAV
  • Comodo
  • ESET-NOD32
  • F-Prot
  • Kaspersky
  • Malwarebytes
  • McAfee
  • Sophos
  • TrendMicro
  • Symantec
  • Windows Defender
While we aim to provide correct and up-to-date information, it is possible that new vulnerabilities will be found before the status has been updated and new software released. If your security scanner detects a new vulnerability, don’t hesitate to contact us to investigate it.
Last update: 2025-08-04
Common false positive detections in AKCP products
By default, all units have the following possibly un-secure configuration. This is to provide the user with ease of access and a simplified installation. It is the end user’s responsibility to change the default settings of the following if they are considered to be security flaws:
SNMP v1/v2 enabled with the community: public
Remediation: change the community to a customized string, and/or disable the SNMP v1/2 protocols (disabling might affect the product’s functionality).
Built-in default SSL certificate for HTTPS: un-trusted self-signed, using a possibly weak hash algorithm
Remediation: the default certificate has to be replaced with a trusted SSL certificate of the user’s choice if HTTPS access is required (we provide manuals for changing the SSL certificates on our units).
Telnet and/or SSH service: enabled by default, where supported
Remediation: disable these services if they are not needed. This might affect the product’s functionality.
SNMP ‘GETBULK’ Reflection DDoS
The SNMP server running on our units is designed to be able to send large amounts of data quickly, if necessary. This is to avoid losing important sensor data and alerting functionality.
Remediation: configure SNMP alerts and SNMP Trap messages with only the necessary information, and distribute sending the alerts to multiple hosts.
sensorProbe+ (SP+) products
LPWAN technologies for IoT
Security status: SECURE
Latest firmware per platform:
F4 1.0.5606
F7 1.0.6195
H7 1.0.6195
Vulnerabilities: NONE
No shell access is provided.
Wireless Tunnel Gateway (WTG)
WTG-with-antennas-and-Modem_small-768x716
Latest firmware: 1.0.419
securityProbe (SEC5) products
Latest firmware: 406g
sensorProbe (SP) products
SP2-small
Security status: ATTENTION
Latest firmware: 480
Security scan results:
AKCPro Server (APS)
AKCess Pro Ltd
VirusTotal scan results:
APS Installer file “AKCProServer-16.2.146.exe”
https://www.virustotal.com/gui/file/06cb0c30f7619056e17e9d24dfb50baf819b63f17ec181a1d3be3a33c959a13e?nocache=1
VirusTotal lists 2 engines detected this file:
Bkav Pro: W32.AIDetectMalware
Xcitium: TrojWare.Win32.Chapak.A@7jwiqv
This is a false positive result, since only 2 of all antivirus engines have detected the file as malicious.
https://www.virustotal.com/gui/file/ad7baa124bcb485abc82ae81b56ee378c11baefe99a9b4f68f86dc87794c3129?nocache=1
https://www.virustotal.com/gui/file/6a4e66bfa3857f8c4cbfac1d85d2212ef46fc8b6852d8cee996f5ae35d839b13?nocache=1
https://www.virustotal.com/gui/file/ed5cfbbd2cfd927d8436aec33f32372d00b4d328a5eddddb5d61f55d59e14e25?nocache=1
https://www.virustotal.com/gui/file/57244881a11569d7696b3201d5cec27cffe43e711296dd21567eef4799272300?nocache=1
https://www.virustotal.com/gui/file/4e1d7bf97919e265eed51803150145be38108d61ea881278cb89fbf056da00bd?nocache=1
https://www.virustotal.com/gui/file/ddd25158f1f98bea64a379f95a8143f8873793c14087646d84d693d3015872e4?nocache=1
https://www.virustotal.com/gui/file/70ebbe5cb72e3e5925fe82e6e44cd40d6721dff9ad1a55995e25bee983d5dea5?nocache=1
https://www.virustotal.com/gui/file/134b35a8f70ad3f853d39c8c55f1889c8bc1df82ff3ccaca69e3510af395260c?nocache=1
https://www.virustotal.com/gui/file/72be5117166bb22d6033f0afb8303662441989b44c6d28c7c083a7641cd032d1?nocache=1
https://www.virustotal.com/gui/file/510186da7bda0ed14f73b9bd146cd4c1e7db9ad3d0dc3e7dfcfda3620d0cb93d?nocache=1
https://www.virustotal.com/gui/file/eadecd5bd5f2778555b6ec2ab96a5fbbf74f7af9fdd1a47ee487d5645c00c859?nocache=1
https://www.virustotal.com/gui/file/83369d6c533c826562353cc2cffef9fceb5200e9e30da280f5c0d0d255d4948e?nocache=1
https://www.virustotal.com/gui/file/babe9c34701ecaabb7b635de5294a65f6a55be69ea915c14adc6adc77bc567e0?nocache=1
https://www.virustotal.com/gui/file/b9b7bb647c2d59a50a952ee451815cdfae77000fb6d9f9a2ecba4f8e37a656eb?nocache=1
https://www.virustotal.com/gui/file/368c099db37a57af744f8d978f5640e64430836ee1a7217dcae7681ce6130c83?nocache=1
https://www.virustotal.com/gui/file/b8ed5b53225c8a5364b35a8fbe3fb20242f7468b5215fe2b6cec2cdd0787cfd5?nocache=1
https://www.virustotal.com/gui/file/36fbcc784567743f8e8f264e1dea137ad77949cc676590decd287f9fe660bee7?nocache=1
https://www.virustotal.com/gui/file/beff9305f3733a0bbade07c47eda3b9eb6f11ab661301374fd689c65824aeb31?nocache=1
https://www.virustotal.com/gui/file/edabc43e48710521f5bd8f5f7ff463d7bbb36a883dde1c7d462e7241d6da1fec?nocache=1
https://www.virustotal.com/gui/file/1c9ba822b7a8c94c39c1b993f5d73fcbd8e0764630ccbc121ed9df28f299d5a0?nocache=1
https://www.virustotal.com/gui/file/efc94dcf252122030914d95b4150aee7d7d8cbf13166c8a4c393b509cd3f346f?nocache=1
https://www.virustotal.com/gui/file/1eb07e34f150fdf26c56b549cc2a3740beadd0b2f21309e44ad041dc529f7137?nocache=1
https://www.virustotal.com/gui/file/538b8f097721141118f7601bda50752627182d578f09d2d37bbc8fbdfe8c6fea?nocache=1
https://www.virustotal.com/gui/file/ca916801c4e1642fe40baa46308fe82e33d053e2649e472c008490379dc7b4e7?nocache=1
https://www.virustotal.com/gui/file/68b35a776d603760c3b0bdb3a8da7cb7f955c85aefc793ea5c709230af5b1d9c?nocache=1
https://www.virustotal.com/gui/file/9a7204348c1fb655c6b91f69131eeb429bad2cf9d5516949f7d3dcc16e502171?nocache=1
https://www.virustotal.com/gui/file/03ff78ca36658a6cff63540098dd81b01187fea61274e2624629f8e9c37e4b20?nocache=1
https://www.virustotal.com/gui/file/30af6cb6ce0a2d85f98961113a7ce347ba6dac991406747c8a8460ae627f673e?nocache=1
https://www.virustotal.com/gui/file/70902e4ffe487bbc75ce63dd744e53762ed38c5b0d9f4ab953d82883a081b15a?nocache=1
