Myths About Airflow Containment
Data centers are crucial infrastructure for the modern world. Data has become a commodity and data centers are the medium to facilitate its flow. Every facet of our life is data-dependent.
For the average person, data centers are not given much acknowledgment. We are aware of their importance but we negate to recognize their function. Their impact on the world has been significant, but also they require huge amounts of energy. Datacenter management, therefore, make sure data infrastructure is run efficiently. There have been developments that enable effective data center management. These include reduction of operating costs by integrating efficient cooling infrastructures. Data centers commonly implement air temperature monitoring to alert too high air intake temperatures. They can also be used to identify overcooling and stranded capacity.
Through taking action improved performance and efficiency are achieved. As such, with better performance is a reliable output and availability of data, decreased carbon footprint, and operating costs. Most data centers these days employ some kind of containment of the hot or cold air. However, there are myths about airflow containment that need addressing.
Common Myths About Airflow Containment
  • Airflow Containment Blocks Bypass Airflows
Bypass air is a complicated subject in data center containment. The  Bypass air issue goes beyond the problem of cold air not flowing through IT hardware. Bypass airflow will only be reduced or eliminated if:
    • There is a decrease in the total air volume provided by the cooling system.
    • There is an increase in air volume as needed by the IT equipment.
Following these disclaimers, it is illogical to assume that air containment by itself reduces bypass airflow. The objective of data center containment should fulfill the aforementioned conditions. As such, containment efforts should focus on the right balance of air volume as required by hardware but at the same time lower the total volume emitted by the cooling units.
  • Containment Will Diminish A Significant Operating Cost
This is not to say the operating costs will not decrease. Airflow containment can lower your costs. But how?
Datacenter containment will result in a significant cost reduction by preventing cold and hot air mixing.
Intake air temperature is maintained first at 75°F to 80°F. This is also the threshold where equipment fans begin to speed up. Given this condition, not a lot of financial benefits can be incurred. The value of airflow containment relies on comprehensively ticking these variables:
    • Reduction of fan speeds of cooling units.
    • Turning the cooling system off.
    • Increasing set points for chilled water.
These are some of the valuable steps in a basic airflow containment framework. However, to gain better leverage in cost reduction, establishing a cooling infrastructure is imperative. This cooling infrastructure must have adequate control adjustments preceding any containment installation.
  • Perforated Tiles Are Not Needed After Containment
To debunk this myth, we must first understand the nature of containment. Containment, alone, negates the conditioned air from mixing with the hot exhaust air. However, containment does not function to balance the flow rate of the conditioned air to the flow rate needed by IT. When the flow rate is not equal, bypass air will find its way into openings. This air excesses are now wasted energy. Deploying perforated tiles is a supplement to gain better airflow balance. It is a must that perforated tiles are used in complementing any containment endeavor as it assures better cost savings in the end.
  • Return Air Temperature Increases Because Of Containment
To associate return air temperature to containment alone is not sound. Return air temperature is a combination of moving air volume in the IT room, the heat load gathered by the IT as well as the set point for the cooling unit. As such, there are more factors to consider in managing return air temperature.
The increased temperature may be credited to the fact that containment may provide a fraction of hot air to flow back to the cooling unit. This, however, has no significant effect on the average temperature of the cooling unit. This is because cooling units have a maintained threshold for air return temperature. They work to follow a pre-programmed set point. As such, despite warmer air flowing back to the unit, effects are fairly limited as the setpoint dictates the whole room temperature.
Ultimately, the task to maintain the setpoint should be integral to the containment plan. It is airflow containment that can dictate when to raise set points. It should also follow adjustment controls according to supply. In this way, airflow containment optimizes cooling unit efficiency and widens its capacity.
Airflow Containment Is Essential And Will Bring Efficient Results
The biggest elephant in the room is relying on containment procedures to account for data center efficiency. No. Just like any other output-based activity, operations will need different facets of management. This includes a comprehensive checklist essential to running data centers.
One particular consideration is making sure that airflow containment has a best-fit monitoring system complementing it. The value of monitoring a data center cannot be understated. With an integrated airflow containment, monitoring is imperative.
Basic monitoring technologies such as airflow sensors are available in the market. These sensors are built to check up on systems generating heat and require maintained airflow to extract it. The AKCP airflow sensor assures system reliability and ensures continuous good airflow.
The effectivity of the AKCP airflow sensor comes from the capacity to monitor the status of air flowing into a room. It is used to detect the presence and absence of airflow. It can be interfaced through a web browser and send alarms when a fault is detected.
AKCP Airflow SensorsTo optimize the effectiveness of airflow containment, air velocity sensors can also be deployed. Supplementing the airflow sensors, AKCP air velocity sensors show information using percentages and graphical displays. It also provides analog values on graphs over some time. Giving users maximum oversight to check on airflow trends. Having these data points enable the data center manager to check on the balance airflow ratio that optimizes cooling efficiency and heat dissipation.
In gathering more comprehensive monitoring indicators, other technologies fit the bill. AKCP Ethernet-enabled sensorprobe is deemed as a stand-alone monitoring utility designed to check environmental and physical threats. It works by plugging any AKCP smart sensors into any of its 8 ports. It can hold sensors for each monitoring metrics such as temperaturehumidityairflowwatervoltage, and security. In a way, customizing your monitoring oversight depends on your operational criteria.
The sensorProbe8 can be pre-programmed with a user-settable threshold. Once data is detected beyond the programmed setpoints, it will prompt an alarm to notify users. In a certain case such as loss of airflow, AKCP sensorProbe can instantaneously validate the current situation. It is also compact and made to fit smaller server rooms, racks where airflow detection is critical.
Data Centers Are Not A Mystery, They Are Critical In Our Lives
For a common person, we truly cannot fathom the scope to which a data center can function. In an industrial age running on online connections, data centers are on top of the echelon to provide us the convenience as we run our lives.
This is why data centers must keep up with the demands of their stakeholders. Data should be fast and smooth. Online transactions are seamless. Digital lifestyles, improved. One way to keep data centers at the top of the game is airflow containment. Optimizing airflow and enabling proper capacities to reduce disruptions is integral in a data center. Because once this is addressed and data centers run smoothly, we get to enjoy the many benefits it provides us.
https://www.upsite.com/blog/5-common-myths-data-center-containment/
https://hardyracks.com/blog/five-data-center-myths-debunked/
LPWAN technologies for IoT
Security status: SECURE
Latest firmware per platform:
F4 1.0.5606
F7 1.0.6136
H7 1.0.6136
Vulnerabilities: NONE
No shell access is provided.
Wireless Tunnel Server (WTS)
AKCPro Server data center hot and cold aisle containment sectional view with wireless sensors
Latest firmware: 1.0.419
securityProbe (SEC5) products
Latest firmware: 406g
sensorProbe (SP) products
SP2-small
Security status: ATTENTION
Latest firmware: 480
Security scan results:
AKCPro Server (APS)
AKCess Pro Ltd
VirusTotal scan results:
https://www.virustotal.com/gui/file/f2c5972b2324b842066a6eedf9bdaac42c9c96e52294b22ddf9135a95fb825e4?nocache=1
Bkav Pro: W32.AIDetectMalware
https://www.virustotal.com/gui/file/eeab89ca7159c208898c444e5194837593e31bc3856532926baf560b98ad7360?nocache=1
https://www.virustotal.com/gui/file/01433de415708f105c1503f4afa780df5f28a5bd0a7e780b73eb491bb0f1b33d?nocache=1
https://www.virustotal.com/gui/file/25f0edc7a0ac8555f4c742929e5996b78ba93adf7054c04b489a6e8c7effd605?nocache=1
https://www.virustotal.com/gui/file/63da65f414b7aa2d50db6b21c9f2e03d0c9f8aba01328dd6723c467f8cfdb8e4?nocache=1
https://www.virustotal.com/gui/file/2f3283f7c9c585a8bdd2a92b3162e20cd300a1d05507e378b15783bb26f24abe?nocache=1
https://www.virustotal.com/gui/file/867be09efe1c6cf1593bf9fc0fa25fb2a21953f5d0f757a38dd0641cd6cb94a0?nocache=1
https://www.virustotal.com/gui/file/cd8a48df34d3795043ea8e0b29122c7665aeb8e2132f84b2aabaacf03ebb10f5?nocache=1
https://www.virustotal.com/gui/file/0f6b56bd30a723a5a6d042b425fcb695fc9cdab4afb834a3375e01d53df4f06e?nocache=1
https://www.virustotal.com/gui/file/688101bfdd4f2f29a2485f6aa0d752dd922b18b9f6fdd4b8a8639d0ae4732acf?nocache=1
https://www.virustotal.com/gui/file/4e32353e6a833db041e22f595e7d1b247b9d00940c05de48df7323e868a5a2e1?nocache=1
https://www.virustotal.com/gui/file/a44ee32ae3d8018469331f8f68278138e95d47a5392250979e586e33aa639a08?nocache=1
https://www.virustotal.com/gui/file/0cc604c469651015a32a9c9c0bdfafb95a90aa63e108467c95f2358e7a659d1f?nocache=1
https://www.virustotal.com/gui/file/1e7982491ff06fd7c003c7e33b850c97a2dca03e01f65f1d1dd18dd1bed3520f?nocache=1
https://www.virustotal.com/gui/file/eb547a9598664b6e2403ac0c8c7bcf725a94e6aaecb023ab141aa055df73bbb0?nocache=1
https://www.virustotal.com/gui/file/09ea3c2bd76a34e97200a63d67e356539c3e92e36c3d4a2d187867780998fd19?nocache=1
https://www.virustotal.com/gui/file/c1e3ac1f8933565d4fc7ff2041c8f1f641e9c1ed4ab06014ea1c924ed152005f?nocache=1
https://www.virustotal.com/gui/file/874158a92a62b6dc9165b38db4e5c166868a33386d0945312e664178701120bb?nocache=1
https://www.virustotal.com/gui/file/0f911f0931a210ac21670e966f5a95353889925a46952ed550bcad49a5be7f85?nocache=1
https://www.virustotal.com/gui/file/fe649654286da9e71ef9e097f0ead1bdc0cefd6f232eb1d41a292b0f5ba5067b?nocache=1
https://www.virustotal.com/gui/file/1256458d055b3a0bc1fc8da47355396f23fd45b571a0c0694b91a64070fd9298?nocache=1
https://www.virustotal.com/gui/file/0a488bdbe3f8297c63e9b3b70be2d557b783e453f4988430071c9187dac1e1f6?nocache=1
https://www.virustotal.com/gui/file/c1a7e86028b4965430fb0a97b1ecc0a94f4d8b656e7ab58125a3c72b670a5770?nocache=1
https://www.virustotal.com/gui/file/a661b60fc5c845fdb9e070a585aea176d4dd2573f07bf197d8b4b67850821429?nocache=1
https://www.virustotal.com/gui/file/c67599ac508f58b0b1358e7bd2fd0362883b93a50718f30fc256677e9fa986a0?nocache=1
https://www.virustotal.com/gui/file/cc5a60a8c51efed995661c53bc3b6b5672a4a262709b7acb0bd595e1e0906853?nocache=1
https://www.virustotal.com/gui/file/497a10c472fcec7708d7eaa397b3e3c79d1dd62eaf3adc7c6d5cda3f318a2978?nocache=1
https://www.virustotal.com/gui/file/986ecd225139c2ffb68d4eb94c0f88ac8735538449f3e6551a337ee175c55ea2?nocache=1
https://www.virustotal.com/gui/file/3e443d89b05db41789ed02a2911a23caa0810e1a8519c46eb927fce3f68bb52e?nocache=1
https://www.virustotal.com/gui/file/e412c7c3c30aefe6bf6e38bd7f716f1ee590ab53ffab4e1be684a1bc5463cecd?nocache=1
