Understanding The Data Center Tier Level System
															So how to identify the right facility for the company? There are many types of data centers that are categorized based on location. As well as sizes and performance capacity. There is another way to categorize data centers. That is the Tier Classification System.
											Tier Level I
- 99.671 % uptime per year.
- 28.8 hours of downtime per year.
- Zero redundancy.
- Backup generator for power outages
- Cooling equipment that can run even after office hours
- IT system area
- UPS for power systems
Tier Level II
- 99.741 % Uptime per Year.
- 22 Hours of Downtime per Year.
- Partial Redundancy.
											- Chillers
- Cooling Units
- Energy Storage
- Engine Generators
- Fuel Cells
- Fuel Tanks
- Heat Rejection Equipment.
- Pumps
- UPS Modules
Tier Level III
- 99.982 % uptime per year.
- 1.6 hours of downtime per year.
- N+1 fault tolerance.
- 72 hours of protection against power outages.
											Tier Level IV
- 99.995 % Uptime per Year
- 26.3 Minutes of Downtime per Year
- 2N+1 Fault Tolerance
- 96 Hours of Protection Against Power Outages
- Zero Single Points of Failure
AKCP for Comprehensive Monitoring
Data Center Monitoring Solution
Whether you are looking for a few temperature and humidity sensors for your computer room or rolling out a multi cabinet monitoring solution, AKCP has an end-to-end data center monitoring solution including sensors and AKCPro Server DCIM software. Our Rack+ solution is an integrated intelligent rack or aisle containment system. Pressure differential sensors check proper air pressure gradients between hot and cold aisles. RFID Cabinet locks secure your IT infrastructure.
Wired or Wireless Sensors
AKCP provides both traditional wired and wireless data center monitoring solutions. Our Wireless Tunnel System builds upon LoRa technology, with specific features designed to meet the needs of data center monitoring. Wireless sensors give rapid deployment, easy installation, and a high level of security. It is the only LoRa based radio solution that has been designed specifically for critical infrastructure monitoring, with instant notifications and on sensor threshold level checking.
AKCPro Server Monitoring Platform
AKCPro Server is a world-class centralized monitoring and management software. Including drill down mapping, drawing program for creating floor plans, graphing, custom dashboards, tablet user interface, synchronization of sensor events with video feeds.
Data Center Infrastructure Management with LoRa™
Deploying a DCIM in your data center is easy.
The AKCP L-DCIM is a DCIM in a box solution with an embedded AKCPro Server. Monitor all your network-enabled devices such as intelligent PDU’s, UPS’s, rectifiers, and CRAC units. Supports SNMP, Ping, and Modbus TCP/IP virtual sensors. Add sensors connected to AKCP base units for a complete end-to-end data center monitoring solution.
Tablet View
															The L-DCIM has a dedicated tablet view user interface, allowing you to monitor your data center stats with drill-down mapping from custom desktops over WiFi while roaming your data center. This allows technicians on the ground to be updated in real-time and respond to critical alerts immediately.
Floor Plan to Cabinet Mapping
AKCPro Server has a simple drawing program to allow you to quickly create floor plan views of your data center, drag and drop sensors into their relevant locations and drill down from a building-wide to an individual cabinet. The mapping user interface can be accessed from a desktop PC or on the roaming tablet view.
Video, Security and Access Control
Connect IP video cameras and record sensor events. Synchronize this recorded video with events in a real-time playback window. Secure your data center with AKCP access control RFID swing handle cabinet locks and monitor and administer your data center access control from a single user interface.
Danica BautistaUnderstanding The Data Center Tier
