Temperature Sensors and Where to Install Them
Data centers are an essential part of modern business. They store, process, and analyze large amounts of data. To optimize the equipment, increase reliability and longevity it is important to keep their environment regulated. With the help of temperature sensors like Temperature and Humidity, Airflow, Air Quality sensors, monitoring your data center for optimal PUE is possible.
Where Should You Place Temperature Sensors?
In-Rack Temperature Sensors Placement
Recommended specific temperature sensors placement also includes:
- Next to the thermostat controlling the room temperature
- The front door of each rack
- Midway on the back of each rack
- On each air circulation plenum space
In-Room Temperature Sensors Placement
How Climate And Weather Conditions Affect Data Centers?
Knowing Your Humidity Threshold
Proper Airflow Management
Data Center Temperature Monitoring
The bigger market for data centers calls for improved performance. With growing users, it is essential to catch up with the business-changing demands. Efficiency and safety have been always the challenge. It is a good thing that a reliable and leading sensor monitoring company like AKCP has a variety of Wired and Wireless Temperature and Humidity monitoring sensors for your data centers.
AKCP Data Center Temperature Sensors is the best way to avoid hotspots in IT cabinets or server racks. Ensuring equipment is running at optimal temperatures will increase its lifespan, reliability and decrease maintenance. ASHRAE recommended standards for data center cooling are a guideline for the temperatures at which a data center should run.
AKCP temperature sensors and cabinet thermal maps monitor your data center and IT cabinets. Use collected temperature sensor data to safely raise air conditioner temperature setpoints without putting mission-critical equipment at risk.
Save on server room cooling costs and lower server room PUE one rack at a time.
For Inquiries, you may reach us through our sales team: sa***@ak**.com
4 Most Common Types of Temperature Sensor
https://www.pyrosales.com.au/blog/news/how-do-temperature-sensors-work/
https://www.elprocus.com/temperature-sensors-types-working-operation/
