Home » AKCP News » AKCP Introduces AQX4: The 4-in-One Environmental Sensor for Healthier Workspaces and Data Centers
AKCP Introduces Air Pollution Sensor: The 4-in-One Environmental Sensor for Healthier Workspaces and Data Centers
AKCP, the world’s oldest and largest manufacturer of networked wired and wireless sensor solutions, today announced the launch of the Air Pollution and Pressure Sensor AQX4, a comprehensive 4-in-one air environment sensor for indoor air quality monitoring.
The AQX4 integrates four critical environmental metrics, temperature, humidity, static air pressure, and air quality index into a single, compact unit. Engineered for versatility, the sensor is ideal for office spaces, industrial facilities, and data centers where maintaining optimal air quality is essential for both human health and equipment efficiency.
A Smart Approach to Air Quality
At the heart of the AQX4 is its advanced Air Quality Index (AQI) “scoring” system. The sensor specifically targets Volatile Organic Compounds (VOCs) and Volatile Sulphur Compounds (VSCs), gases commonly produced by chemical off-gassing, plastics, and exhaust.
The AQX4 provides a real-time “pollution level” percentage based on gas resistance:
- Clean Air (0%): Gas Resistance ≥50 kΩ.
- Normal to Warning (0–65%): 50 kΩ>Resistance>18 kΩ.
- Critical to Max (85–100%): 5 kΩ≥Resistance>1.5 kΩ.
“In data centers, air quality is often an overlooked aspect of uptime,” says Nicholas Barrowclough, President at AKCP. “By monitoring these levels, facilities can create automated alerts to open doors or windows, ensuring fresh air circulation before conditions reach critical thresholds”.
Technical Specifications & Compact Design
The AQX4 is designed for precision and easy integration into existing monitoring systems:
- Dimensions: A compact form factor measuring approximately 25.24 mm in length and 16.64 mm in height.
- Precision Sensing:
- Temperature: Range of −40∘C to +85∘C with ±0.5∘C accuracy (at 25∘C).
- Air Pressure: Range of 300 to 1100 hPa with ±0.05 hPa relative accuracy.
- Humidity: 0 to 100% RH with ±3% typical accuracy.
About AKCP
Established in the USA in 1981, AKCP is a pioneer in environmental monitoring technology. With over 40 years of experience and more than 200,000 installations worldwide, AKCP provides the infrastructure needed to protect critical assets and optimize energy efficiency.
