Home » AKCP Blog » AKCP launches Daisy-Chainable Temperature Sensor
Bangkok, Thailand – 30 July 2008. AKCP Inc., the oldest and largest manufacturer of SNMP-based devices for environmental and security monitoring solutions has released the daisyTemp. The AKCP daisyTemp is a daisy-chainable temperature sensor solution designed for efficient temperature monitoring.
Up to 8 daisyTemp sensors can be linked together and plugged into one securityProbe Intelligent Sensor port enabling the unit to measure up to a maximum of 64 temperature points. The daisyTemp can measure temperatures between -55°C to +75°C with a ±0.5°C accuracy.
Collected temperature values can be used to trigger alerts like e-mail, SMS, phone calls and SNMP traps. With the securityProbe unique mapping feature you can place these sensors on a map so you can quickly identify where you may have hotspots. Each temperature sensor has its own SNMP OID so that the data can be collected over the network using any Network Management System.
Each daisyTemp comes with a free 5 feet sensor cable. The sensor cables can be extended using Ethernet cable with a maximum daisy-chain length of 500 ft.
The daisyTemp is available immediately and can be purchased individually for $75 with bundle packs of 4 and 8 temperature sensors available for $275 and $500 respectively.
About AKCP
AKCP Inc., established in 1981, is the world’s oldest and largest manufacturer of SNMP based environmental and security monitoring solutions. Over 35,000 installations use AKCP for disaster prevention and infrastructure security.
Jim Jeffords
AKCP Co., Ltd.
Office 9A, Wang Dek Building,
Jatujak, Bangkok 10900,
Thailand.
Tel: +66-2-617-8998
Email: mk**@ak**.com
URL: https://www.akcp.com
