Home » AKCP Blog » Changes to the securityProbe 5E Standard’s SD Flash Memory
There are some important changes to the securityProbe 5E Standard Range. From 12th March 2012 the removable SD Flash card will no longer be supplied with this unit.
The SD card slot will remain enabling users to use a SD Flash memory card of their choice if required. The securityProbe 5E Standard range will have an onboard NAND flash cell with 128 MB memory.
This change applies ONLY to the following units (SEC5ES, SEC5ES-X20 and SEC5ES-X60)
For more information contact sa***@ak**.com
