Home » AKCP Blog » Data Center Dew Point Calculator | AKCP
Data Center Dew Point Calculator: Check Humidity and Condensation Risk.
A data center can have a comfortable room temperature and an apparently reasonable humidity reading while a cold pipe is close to collecting water. The missing measurement is often the temperature of the surface itself.
Condensation risk depends on how close that surface is to the dew point of the surrounding air. As liquid cooling adds pipes, fittings and coolant distribution units to the data hall, this comparison becomes an increasingly useful part of routine environmental checks.
The AKCP Dew Point & Humidity Calculator helps you make that comparison. Enter local air temperature and relative humidity, add the coldest exposed surface temperature, and review the available margin. You can also test a different air temperature, account for measurement uncertainty and compare readings with selected IT inlet limits.
Use the data center dew point and humidity calculator
Start with measurements taken together at the location you want to assess. For a CDU fitting, use nearby air conditions and the fitting’s exposed surface temperature. For an IT operating-envelope check, use air readings at the equipment inlet.
Data Center Dew Point & Humidity Calculator
Check the moisture in your air, identify condensation risk on cold surfaces, and see how a temperature change affects relative humidity.
1. Air conditions
Enter temperature and RH, or calculate RH from a known dew point.
2. Cold-surface check
Useful for exposed pipes, CDU fittings, cold plates and equipment arriving from a cooler storage area.
Allow for measurement uncertainty
Illustrative ± allowances; replace with your sensor accuracy and installation allowances. The worst-case screen combines high air temperature, high RH and low surface temperature. It is a bound, not a statistical confidence interval.
3. IT inlet operating limits
A screening comparison with the selected limits. An inlet-envelope pass does not establish that a cold pipe is free of condensation.
Custom operating limits
4. Change air temperature
See the RH after a temperature change with no moisture added or removed, at constant pressure. Heating air lowers RH but does not lower its dew point.
How to use this in a data center
- Use the right location. Read temperature and humidity together near the cold surface. Use inlet measurements for IT envelope checks; room averages can hide local conditions.
- Compare surfaces with dew point. A surface at or below dew point is at saturation or can collect condensate. Check exposed fittings, valves and insulation gaps; an insulated pipe's outside surface differs from coolant temperature.
- Review the uncertainty result. A nominal margin can disappear when sensor accuracy, humidity gradients and transient conditions are considered. All safety allowances here are editable examples.
- Follow the equipment requirements. These presets screen recommended air-cooled inlet conditions. They do not implement all allowable classes, altitude derating, change-rate limits, tape-storage requirements, corrosion controls or liquid-cooling specifications.
- Combine prevention and detection. Trend local air and surface temperature and use water leak detection near vulnerable equipment. A dew point calculation cannot detect an actual leak.
Calculation method, assumptions & sources
This calculator uses a Magnus approximation over liquid water. Air inputs are limited to 0–50°C and 1–100% RH. Sub-zero calculated dew points are referenced to liquid water and are not frost points; freezing-surface analysis needs an ice-based method. Very dry conditions and sensor uncertainty reduce confidence in derived results.
e = (RH / 100) × eₛ(T)
γ = ln(RH / 100) + 17.62T / (243.12 + T)
Td = 243.12γ / (17.62 − γ)
RH from dew point = 100 × eₛ(Td) / eₛ(T)
P = 101.325 × (1 − 2.25577 × 10⁻⁵z)5.2559 kPa
W = 0.621945e / (P − e) kg water / kg dry air
Absolute humidity = 2166.79e / (T + 273.15) g/m³
Enthalpy ≈ 1.006T + W(2501 + 1.86T) kJ/kg dry air
Nominal margin = surface temperature − Td
Required surface = Td + chosen margin
Surface RH ceiling = min[100, 100 × eₛ(surface − margin) / eₛ(T)]
T, Td and surface temperatures are in °C; z is altitude in metres. °F differences convert using ×1.8 without a 32-degree offset. Altitude changes estimated humidity ratio and enthalpy; it does not alter dew point inferred from a measured temperature/RH pair.
Preset basis. The 2021 A1–A4 screen uses 18–27°C and −9 to 15°C dew point; H1 uses 18–22°C. The RH cap is 70% only for verified low corrosion conditions; high corrosion requires a 50% cap. The default 50% profile is a cautious site-screening choice for unverified conditions, not evidence of measured pollution. The legacy 2015 profile uses 18–27°C, −9 to 15°C dew point and 60% RH; H1 was not defined in that edition. Every active temperature, dew point and RH constraint must pass together.
Sources: Sensirion SHT1x datasheet, dew point method; ASHRAE Journal, May 2022: air-cooled thermal guidelines, Tables 1–2; Vaisala: dew point and condensation.
Turn a one-time check into ongoing monitoring
AKCP temperature and humidity sensors provide local readings, and sensorProbe+ supports calculated dew point. Pair environmental monitoring with surface temperature checks and water leak detection around cooling equipment.
Planning estimate only. Confirm limits with your equipment supplier and facility engineer. This standalone calculator does not connect to your monitoring system or set alarms. © AKCP · Dew Point & Humidity Calculator v1.0
The calculator’s example values are editable. Its 3°C surface margin is an illustrative planning allowance; select a margin appropriate to your equipment, measurement accuracy and operating conditions.
What dew point tells you that relative humidity cannot
Relative humidity describes how close air is to saturation at its current temperature. Dew point is the temperature at which that air becomes saturated when cooled at constant pressure without changing its moisture content.
For example, air at 24°C and 45% RH has a dew point of approximately 11.3°C. An exposed surface cooled to that temperature reaches the condensation boundary. A colder surface can collect water even though the room humidity sensor still reads 45%.
This is why a humidity reading needs context. To assess a cold surface, compare its temperature with the local air’s dew point.
AKCP introduced this approach to its monitoring platform in our article on dew point calculation with sensorProbe+, which explains how combined temperature and humidity readings provide the inputs for calculated dew point.
Calculate the margin above dew point
The practical comparison is straightforward:
Dew point margin = exposed surface temperature − local air dew point
Using the same 24°C, 45% RH air conditions, the calculator gives these approximate results:
| Exposed surface | Margin above dew point | Interpretation |
| 18°C | 6.7°C | Exceeds the example 3°C nominal allowance. |
| 13°C | 1.7°C | Above dew point, but below the example allowance. |
| 11.3°C | Approximately zero | At the condensation boundary. |
| 10°C | −1.3°C | Below dew point; condensation is possible. |
A positive result is useful, but consider how much clearance remains when humidity rises or the surface becomes colder. The uncertainty section estimates a worst-case margin using your entered sensor allowances. It is a screening bound, rather than a statistical confidence interval.
For an insulated pipe, measure the outside of the insulation and check joints and exposed fittings separately. Coolant temperature can help with an initial screen, but it is not automatically the temperature of every exposed surface.
Why this matters around liquid cooling equipment
Liquid cooling brings more surfaces into the data hall whose temperatures may differ substantially from the air around them. During a review, useful places to check include CDU connections, valves, manifolds, hose fittings and gaps in pipe insulation.
Consider a second calculator example: at 24°C and 65% RH, dew point is approximately 17.0°C. An exposed fitting at 15°C sits about 2°C below that boundary. Warm room air does not prevent condensation on the fitting.
Review the margin when changing cooling settings, commissioning new racks or investigating dampness. Repeat the check under the conditions that matter to the installation, including humid weather and changes in ventilation. The cause may be a colder surface, an increase in air moisture, or both.
Any change to coolant settings must also meet the cooling system and IT equipment requirements. Where the surface temperature cannot be raised, appropriate insulation and control of air moisture may be needed.
How dew point relates to mold risk
Moisture risk also extends to the building: underfloor spaces, insulation, wall finishes and ceiling voids. AKCP’s article on mold risk and environmental risk indices in data centers explores the relationship between air temperature, RH, dew point and surface temperature.
A surface does not need visible droplets to experience prolonged high humidity. With 24°C air at 45% RH, an illustrative calculation gives approximately 90% RH immediately next to a 13°C surface, assuming the same vapor pressure. The surface remains above the 11.3°C dew point, yet its local moisture conditions are very different from the room reading.
ASHRAE’s building-moisture guidance identifies persistent high surface humidity as a concern for mold growth. Duration, temperature, material susceptibility and available nutrients all matter. A brief humidity excursion does not establish that mold is present.
The calculator assesses dew point and condensation clearance; it does not produce a validated mold growth index or probability. Use repeated measurements, inspection and a suitable moisture assessment when investigating persistent dampness.
Humidity and corrosion need different checks
The moisture conditions that affect building materials can also matter to electronic equipment. Corrosion risk depends on the surrounding contaminants as well as humidity; a room humidity number cannot establish the condition of the air or the risk to a circuit board.
This distinction appears in the calculator’s ASHRAE 2021 presets. The recommended upper humidity boundary combines a 15°C dew point cap with an RH cap that depends on corrosion conditions: 70% RH for verified low corrosion, or 50% RH for high corrosion. Both moisture constraints apply together.
The default 50% profile is a cautious screening choice for unverified conditions. Choosing the 70% profile requires evidence of low corrosion; an ordinary temperature and humidity reading does not provide that evidence.
Which operating limits should you select?
The calculator offers 2021-based profiles, a labelled 2015 reference and custom site limits. Its 2021 recommended air temperature ranges are 18–27°C for A1–A4 and 18–22°C for the specific H1 air-cooled equipment class. The recommended dew point range is −9 to 15°C.
These checks apply to IT inlet air. A result within the selected envelope can coexist with condensation risk on a colder pipe elsewhere in the room. Equipment requirements, altitude effects and other operating restrictions still need their own review.
Use custom limits when the equipment manufacturer or your facility operating policy requires a different range. H1 is a defined equipment class, not a label to apply automatically to every high-density rack.
Will warmer air solve a humidity problem?
Warming air lowers its RH when pressure and moisture content stay constant. It does not lower the dew point.
In the first example, warming air from 24°C to 27°C reduces RH from 45% to approximately 37.7%. Dew point remains approximately 11.3°C. If an exposed fitting remains at 10°C, it is still below dew point.
The temperature-change comparison makes this distinction visible. A lower RH after warming does not demonstrate that moisture has been removed. Lowering dew point requires removing water vapor; raising the exposed surface temperature can also increase its clearance.
Turn a calculator check into a monitoring routine
The calculator is useful for planning and investigating a particular reading. Continuous monitoring shows whether the condition is occasional, persistent or worsening.
AKCP combined temperature and humidity sensors provide local measurements through a single sensor port, and sensorProbe+ supports calculated dew point. Use those readings alongside surface temperature measurements to assess cold equipment.
A practical routine is to:
- Measure in the right place. Use IT inlet readings for equipment checks and nearby air readings for a cold-surface assessment.
- Identify the coldest exposed surfaces. Check fittings, insulation gaps and other likely cold spots.
- Track the margin over time. Review trends during cooling changes and periods of humid weather.
- Investigate moisture sources. Check ventilation, humidification, insulation and condensate drainage when dew point rises or surfaces become damp.
- Use water detection where needed. A dew point estimate indicates a condition that could produce condensate; a water sensor can detect liquid that has reached its sensing area.
Start with the calculator, then use measured trends to decide where further monitoring or corrective work is needed. For help selecting sensors for your data center, contact AKCP.
What is dew point in a data center?
Dew point is the temperature at which the local air becomes saturated when cooled at constant pressure without changing its moisture content. Comparing it with a cold surface helps assess condensation risk.
Can condensation occur when room humidity is 45%?
Yes. At 24°C and 45% RH, dew point is approximately 11.3°C. A colder exposed surface can collect condensate even though the room reading remains 45%.
What margin should I maintain above dew point?
Select a margin based on the equipment, sensor uncertainty and expected changes in conditions. The calculator’s 3°C example is editable and is not a universal design requirement.
Does the calculator predict mold growth?
No. It calculates dew point and condensation clearance. Mold assessment also requires information about exposure duration, materials and persistent moisture conditions.
Does increasing room temperature lower dew point?
No, if pressure and moisture content remain unchanged. RH falls as air warms, but dew point stays the same. Check the temperature-change comparison to see the difference.
Can I use coolant temperature for the surface check?
Use it as an initial screening proxy when a surface measurement is unavailable. For a more useful assessment, measure exposed fittings and the outside of insulation, whose temperatures may differ from the coolant.
Can sensorProbe+ calculate dew point?
Yes. sensorProbe+ calculates dew point using readings from an AKCP combined temperature and humidity sensor. See AKCP’s dew point calculation article for background.
