Fuel Cells to Power the Future with AKCP Power Monitoring
What is a Fuel Cell?
How do Hydrogen Fuel Cells work?
What are the Types of Fuel Cells?
Two Types of Fuel Cells Used by these Fuel Cell-Powered Data Centers:
PEM or Proton Exchange Membrane Fuel Cells
Solid Oxide Fuel Cells
Avoiding Downtime
When doing an ocular search for probable locations of a data center, one of the factors that must be taken into consideration is that the site must have a solid connection to an electric grid. This is in the event that the fuel cells generate inadequate voltages or not enough electrical power. This could lead to server damage or failure. Which could result in data center downtime.
However, having a complete picture of your power chain from fuel cells to rack to PDU gives an accurate overview of the power system. Voltage, KW, KW/H, and Amperage data are displayed, allowing you to see where the system is less efficient than it could be. This can prevent main breakers tripping, and overloads which result in costly downtime. By employing intelligent, switched PDU’s you gain remote power management for individual outlets.
Power Capping
Energy Storage Devices
Power Monitoring Systems
Power Monitoring systems are available from many of the well-known data center providers such as AKCP. The AKCP power monitoring system has several advantages over many other systems. They provide a device that will upgrade any existing power strip to a smart, intelligent monitored PDU. The system also includes patent-pending technologies such as in-cabinet Fire Suppression Systems (FSS) to distribute boot sequencing.
Managing the fuel cells in your data center through the AKCP system is automated with power numbers being collected at a central point in AKCPro Server DCIM software and analyzed to automatically calculate PUE numbers. Track total data center consumption, identify power-hungry racks, monitor UPS systems via SNMP virtual sensors, and much more.
Benefits of Power Monitoring Systems
By combining environmental and power data together you can fine-tune your data center cooling to ensure that you are always running most efficiently.
- Power monitoring systems such as the one available from AKCP, give a wealth of information, but also analyze and alert based on user-defined thresholds. Receive E-mail, SNMP traps, SMS messages, activate alarms, and actuate relay actions based on a sensor status.
- AKCPro Server monitoring software gives the facility to monitor and manage your power sources such as fuel cells. Monitoring the battery’s internal resistance, battery cycles and in the event of power outages, the battery time remaining based on current power consumption. Making sure that your fuel cells are in optimal condition.
- By lowering energy costs you save money on your operational overheads and qualify for certain Energy stars and green certifications by lowering your carbon footprint.
