Home » AKCP Blog » Thermal Imaging Cameras for Data Centers | AKCP
Thermal Imaging Cameras in Data Centers: Security, Fire Prevention and Predictive Maintenance
- perimeter intrusion detection in darkness and difficult lighting;
- early identification of abnormal heat in electrical and mechanical equipment; and
- condition-based and predictive maintenance.
Thermal imaging, IR night vision and thermal mapping are not the same
How thermal cameras improve data center physical security
Perimeter intrusion detection in darkness
Early detection of electrical and mechanical problems
- utility feeds, transformers and switchgear;
- busways, automatic transfer switches and generator connections;
- UPS systems, battery strings and battery terminals;
- power distribution units, remote power panels and circuit breakers;
- cable joints, lugs and terminations;
- cooling pumps, motors, bearings, compressors and air-handling equipment; and
- server power supplies, rack PDUs and other accessible surfaces.
Thermal imaging for early fire warning
Thermal imaging and data center cooling
Handheld surveys or fixed thermal monitoring?
How to select a thermal camera for a data center
| Thermal measurement | Usually optional | Radiometric measurement required |
| Resolution and lens | Sized for target detection, recognition and scene coverage | Sized so the smallest component or connection has enough measurement pixels |
| Thermal sensitivity | Lower NETD improves contrast and analytics stability | Lower NETD helps reveal small temperature differences |
| Analytics | Person/vehicle classification, tripwire, loitering and tamper alarms | Regions of interest, absolute temperature, Delta T and rate-of-rise alarms |
| Visual verification | Dual-sensor camera or paired visible-light PTZ preferred | Paired visible image helps identify the exact component |
| Integration | VMS, access control, ONVIF events and alarm I/O | BMS/DCIM/NMS through supported protocols, alarm I/O or API |
| Environmental protection | Suitable IP/IK rating, operating range and weather performance | Correct operating range, mounting, focus and calibration for the room |
| Cybersecurity | Unique credentials, HTTPS, least privilege, signed updates, logs and network segmentation | The same controls, plus restricted access to alarm and measurement configuration |
Cybersecurity requirements for network thermal cameras
- unique device identities and non-default credentials;
- HTTPS and encrypted management connections;
- role-based access with least privilege;
- network segmentation from production IT workloads;
- signed firmware and a documented security-update process;
- centralized time synchronization, logging and alert forwarding;
- disabled unused services and interfaces; and
- lifecycle planning for vulnerability disclosure and end-of-support.
Relevant data center and thermography standards
- ISO/IEC 22237-6:2024 specifies requirements and recommendations for physical security systems in data center facilities and infrastructure.
- ANSI/TIA-942-C covers data center architecture, power, cooling, telecommunications, fire protection, physical security, safety, monitoring and surveillance.
- NIST SP 800-53 Rev. 5, PE-6 addresses monitoring physical access to facilities containing information-system components.
- ISO 18434-1:2008 provides general procedures for infrared thermography in machine condition monitoring, including emissivity, reflected temperature, severity criteria and reporting.
- ISO 18434-2:2019 provides guidance for thermogram interpretation and diagnostics.
- NFPA 70B (2026) establishes requirements for electrical equipment maintenance and includes infrared thermography as a predictive-maintenance technique. Apply it together with relevant electrical-safety requirements and local regulations.
- ASHRAE Thermal Guidelines, Fifth Edition (2021) provides recommended and allowable environmental envelopes for air- and liquid-cooled IT equipment, along with guidance on facility temperature and humidity measurement.
Integrating thermal imaging with AKCP monitoring
Can thermal cameras see through data center cabinets?
No. A thermal camera measures infrared energy from the visible surface. It cannot see through closed metal doors, walls or standard glass. An open panel or purpose-designed infrared inspection window may provide access to internal components, subject to the site’s electrical-safety procedures.
Can a thermal camera replace rack temperature sensors?
No. Thermal cameras measure surface radiation, while rack sensors measure the air entering and leaving IT equipment. Use calibrated rack inlet and exhaust sensors for continuous environmental monitoring and use thermal imaging for inspection, pattern recognition and anomaly detection.
Are thermal and IR night-vision cameras the same?
No. A thermal camera creates an image from emitted infrared energy and may measure temperature. An IR night-vision camera illuminates a scene with near-infrared light and records the reflection. IR night vision improves visibility in darkness but does not produce a temperature map.
Can thermal imaging prevent a data center fire?
Thermal imaging can detect some abnormal hot surfaces early enough for corrective action, but it cannot detect every developing fire and does not replace smoke detection, fire alarms or suppression. It should be one layer in the facility’s fire prevention and electrical maintenance program.
What equipment should be included in a data center thermal survey?
Prioritize the complete critical power and cooling chain: transformers, switchgear, generators, automatic transfer switches, UPS systems, batteries, busways, PDUs, breakers, cable terminations, cooling pumps, motors and other assets whose failure could affect uptime. The route and interval should be based on criticality, equipment condition and the electrical maintenance program.
