Home » AKCP Blog » Data Center Cooling Load Calculator: How Much Cooling Do You Need?
A row of new servers arrives, the rack power budget goes up, and someone asks whether the existing cooling can cope. The room may feel cold. The air conditioners may still have capacity on paper. Neither tells you how much heat the new equipment will produce, or whether enough cooling will reach it.
The starting point is electrical power. In a steady-state estimate, 100 kW consumed by IT equipment becomes approximately 100 kW of heat. Add the heat from other equipment and the room itself, then determine how much must be removed through air cooling and how much is carried away by liquid.
The AKCP Data Center Cooling Load Calculator brings those inputs together. Use it to estimate room heat load, compare expansion scenarios and prepare the numbers for a cooling review.
Use the Free Data Center Cooling Load Calculator
Enter total IT power or build a list of rack groups. Add relevant room loads, choose a growth scenario, and compare cooling arrangements. Results include kW thermal, BTU/h, refrigeration tons, airflow, pure-water flow and the number of room cooling units needed for N, N+1 or 2N.
You can copy the results, download a CSV report or print a summary to PDF. The calculator runs in your browser and does not send your inputs to AKCP.
Estimate the heat your cooling system needs to remove. Plan room cooling, airflow, liquid cooling and spare capacity from your actual IT power.
1. IT equipment load
Use coincident electrical input at the IT equipment. Measured rack/PDU power is more useful than summed nameplate ratings.
Enter actual or expected coincident kW per rack, including IT power supply losses. No extra utilization multiplier is applied.
2. Other heat in the room
UPS heat losses
Losses = UPS output × (1 / efficiency − 1). UPS output is assumed to equal IT power. Use manufacturer losses in “Other sensible heat” for idle losses, charging or a different output load; then select “Excluded.”
People, ventilation and moisture
People defaults are editable illustrative allowances, not design values. Additional air/moisture loads are entered manually to avoid treating dry-bulb temperature alone as a complete ventilation model.
3. Cooling capacity planning
Growth and allowance are shown separately from today's heat load. These example values are not recommended design margins.
4. Airflow and water flow
Flows use the planned load including growth and allowance. Airflow uses sensible room load; pure-water flow uses the selected thermal duty.
Optional: cooling energy and cost
A constant-load scenario for today's combined room + liquid heat. It excludes growth, planning allowance and unused spare capacity. Actual annual use varies with workload, weather and economizer operation.
How this cooling load calculator works
The calculator estimates a single room's steady-state heat balance. IT electrical power becomes heat; only the fraction carried outside the room's air-cooling boundary is moved to the liquid duty. The diverted heat remains part of the combined thermal load.
Room latent = people latent + extra ventilation / moisture latent
Room total = room sensible + room latent
Future IT = current IT × (1 + growth / 100)
Planned loads = future loads × (1 + planning allowance / 100)
Duty units N = round up the larger of planned total / usable total per unit and planned sensible / usable sensible per unit
Air volume (m³/s) = planned room sensible kW / (air density × 1.006 × air ΔT)
Pure-water volume (L/s) = selected planned kW / (0.998 × 4.18 × water ΔT)
Cooling electrical kW = today's combined thermal kW / effective system COP
1 kW ≈ 3,412.14 BTU/h · 1 refrigeration ton = 12,000 BTU/h ≈ 3.516853 kW
Air specific heat is approximated as 1.006 kJ/(kg·K). Water properties are approximated as 4.18 kJ/(kg·K) and 0.998 kg/L. Glycol mixtures and other coolants need their own properties. A temperature difference of 1°C equals 1 K or 1.8°F.
UPS efficiency is held constant as IT load grows. Other entered loads stay constant. Planning allowance is applied to sensible, latent and diverted liquid duties. It is a user-selected scenario, not a prescribed sizing factor.
Capacity boundary: unit count applies to room cooling only. Liquid equipment is not sized here. N+1 adds one spare identical unit; 2N adds a complete second set. Counts assume independent usable units, suitable controls and distribution, and no common failure. Neither option certifies a facility availability tier.
Model limits: this is not a dynamic peak-load, psychrometric or code-compliance calculation. Building thermal storage, weather, solar timing, diversity, condensation, humidification, reheat, standby losses and duct/system effects are not automatically modeled. Enter relevant loads once, using consistent room and system boundaries. Check both total and sensible capacity at actual operating conditions and separately verify latent capacity.
Technical references: NIST unit conversions; Schneider Electric: Calculating Total Cooling Requirements for Data Centers; ASHRAE Handbook: Cooling and Heating Load Calculations. References support the underlying engineering principles; this simplified tool does not claim certification or standard compliance.
Cooling load calculator FAQs
Is cooling kW the same as electrical kW?
No. Thermal kW is the rate of heat removal. Cooling electricity depends on system efficiency. For example, 100 kW of heat removal at an effective COP of 4 requires approximately 25 kW of cooling electricity.
Why separate sensible and latent cooling?
Sensible cooling lowers temperature; latent cooling removes moisture. A unit's total capacity alone does not establish whether it can handle a data center's sensible heat or moisture load.
Does containment reduce the heat produced by IT?
Containment does not reduce the heat generated at a given IT power. It can improve delivery of cooling air and reduce mixing. Validate rack inlet temperatures and airflow instead of applying an arbitrary heat-load discount.
Can I use this for direct-to-chip or rear-door cooling?
Yes, as a heat allocation estimate. Enter the percentage of IT heat actually carried outside the room's air-cooling boundary. Confirm residual air load, CDU capacity and liquid flow using equipment data.
Should I enter UPS input power as IT power?
Prefer IT equipment or rack/PDU power after upstream losses. If you use UPS input power, do not add UPS losses again. Charging and other non-IT loads can make UPS input a poor proxy for IT power.
How do I validate the estimate?
Compare entered IT power and cooling capacity with measured power, rack inlet temperatures, supply and return temperatures, humidity and airflow. Adequate aggregate capacity can still coexist with local hot spots.
Turn the estimate into measured evidence
Use AKCP monitoring to track operating conditions and compare your cooling plan with what is happening at the racks.
AKCP cooling planning tool · v1.0 · Calculations run in your browser. No inputs are sent or stored by this widget. Rounded values are for display; full precision is used internally.
How to Calculate Data Center Cooling Load
For room cooling, the calculation is:
Room cooling load = IT heat released to room air + other sensible heat + latent heat
Sensible heat raises temperature. IT equipment, lights and electrical losses contribute to it. Latent heat is associated with moisture removal, including moisture introduced by people and incoming air. Both matter when selecting cooling equipment, because a unit’s total capacity does not tell you its sensible or moisture-removal capability.
The calculator keeps those loads separate. It also shows heat diverted to liquid cooling and the combined room-plus-liquid duty, so a reduction in room air load is not mistaken for a reduction in the heat produced by the IT equipment.
Start with Measured IT Power
Use real power in kW at the racks or IT equipment. For an existing facility, select measurements that represent the workload you intend to support. An overnight average may miss a busy production period; adding every equipment nameplate rating can substantially overstate normal demand.
For an expansion, use the expected simultaneous load of the proposed configuration. Keep a record of whether each input is measured, forecast or a manufacturer estimate.
Add Losses at the Right Location
A UPS supplying 100 kW at 96% efficiency has approximately 4.17 kW of conversion losses:
UPS losses = 100 ÷ 0.96 − 100 = 4.17 kW
Include the portion released into the room being assessed. A UPS in a separate electrical room adds to that room’s cooling requirement. Do not add its losses again if your input measurement already includes them.
The calculator’s efficiency model assumes UPS output equals IT power. For charging heat, idle losses or a different UPS output load, use appropriate manufacturer data in the other sensible heat input and disable the modeled UPS contribution.
How to Use the Calculator for a Cooling Review
- Define the room boundary. Identify the IT equipment, UPS, distribution equipment and cooling components whose heat is released into this room.
- Enter the heat sources. Add IT power, lighting, people, envelope heat gain and relevant ventilation or moisture loads. The tool accepts your envelope estimate; it does not calculate it from building construction.
- Allocate liquid heat correctly. Enter only the IT heat carried outside the room’s air-cooling boundary.
- Separate expansion from allowance. Planned IT growth changes the modeled IT load. A planning allowance is applied afterward. Use justified values rather than stacking margins into every input.
- Use usable unit capacities. Enter total and sensible capacity at the intended operating conditions, then select the redundancy arrangement. Check moisture removal separately.
Worked Example for a 100 kW Data Center Room
The calculator starts with the following editable example. It assumes all IT heat goes to room air, UPS losses are excluded, and additional sensible and ventilation loads are zero.
| Heat source | Example input | Cooling contribution |
| IT equipment | 20 racks at 5 kW per rack | 100.00 kW |
| Lighting | 500 W | 0.50 kW |
| People | 2 people at 75 W sensible and 55 W latent each | 0.26 kW |
| Envelope and solar gain | User-entered estimate | 2.00 kW |
| Total room load | 102.76 kW |
That is approximately 350,632 BTU/h or 29.22 refrigeration tons. With zero IT growth and an illustrative 10% planning allowance, planned room capacity becomes 113.04 kW, including approximately 112.92 kW sensible.
Now assume each cooling unit provides 50 kW total and 47 kW sensible capacity at the required conditions. Two units offer 100 kW total and 94 kW sensible, which is insufficient. Three duty units cover both planned loads. Selecting N+1 adds a fourth unit as the spare.
The room still has a planned thermal duty of 113.04 kW. Installing four units adds available equipment capacity; it does not create four units’ worth of heat.
Using the example air temperature rise of 10°C and air density of 1.2 kg/m³, planned sensible airflow is approximately 33,672 m³/h. For the planned room coil duty, pure water with a 5°C temperature rise requires approximately 325 L/min. These are energy-balance estimates; actual distribution, pressure drop and minimum equipment flow remain separate checks.
All example inputs, including occupant allowances, unit capacities and the 10% allowance, are illustrative. They are not AKCP design recommendations.
What Liquid Cooling Changes
Liquid cooling changes where the heat goes. Suppose the same 100 kW IT load transfers 80% of its heat to a liquid circuit that carries it outside the room’s air-cooling boundary. The IT contribution to room air falls to 20 kW, while the diverted liquid duty is 80 kW.
With the example’s other room loads unchanged, current room cooling duty becomes 22.76 kW. Combined room-plus-liquid heat remains 102.76 kW.
This distinction is important for direct-to-chip, immersion and rear-door systems. Confirm the actual heat-capture fraction for the proposed equipment. If a CDU collects liquid heat and releases it back into the same room air, that heat has not left the room’s air-cooling boundary.
The tool shows a liquid duty and a pure-water flow estimate, but does not size the CDU, pumps, heat exchangers or heat-rejection plant. CDU losses released into the room should be entered as additional sensible heat.
Cooling Capacity and Airflow Need Separate Checks
A room can have enough cooling capacity in aggregate and still have a hot rack. Air may bypass the equipment, recirculate from exhaust to inlet, or be delivered to an area that no longer needs it.
The calculator estimates airflow using the planned sensible load and the supply-to-return temperature rise you enter. At the same heat load, a larger temperature rise gives a lower theoretical flow requirement. That is not permission to raise temperatures without checking rack inlet conditions and equipment requirements.
Containment can improve cooling delivery and reduce mixing. It does not reduce the heat produced by a server drawing the same electrical power. Treat airflow improvements as changes to distribution and cooling operation, not as an arbitrary discount on IT heat.
The water-flow calculation follows the same energy-balance principle. It uses approximate pure-water properties. Glycol mixtures and other coolants require different fluid properties and a separate hydraulic review.
Estimate Cooling Electricity Without Confusing It with Heat Load
Thermal kW describes heat removal. Electrical kW describes power consumed. A cooling system removing 100 kW of heat at an effective coefficient of performance, or COP, of 4 uses approximately 25 kW of electricity.
The optional cost calculation divides today’s combined room-plus-liquid heat by the effective system COP, then applies annual operating hours and your electricity tariff. Define COP consistently, including the cooling fans and pumps within the chosen electrical boundary.
This is a constant-load cost scenario. Actual annual electricity use changes with workload, weather, part-load efficiency and economizer operation. Moving heat to liquid may change system efficiency, but the liquid percentage alone does not establish an energy saving.
Validate the Estimate with AKCP Monitoring
The most useful follow-up is to compare the calculation with operating measurements. Track rack power alongside inlet temperatures, supply and return temperatures, humidity and airflow. Review what changes during busy workloads and cooling maintenance.
AKCP sensorProbe+ devices provide a platform for environmental monitoring. Thermal Map Sensors help reveal conditions across a cabinet, while airflow monitoring adds evidence about cooling delivery.
Quicklime DCIM brings AKCP monitoring and supported third-party equipment data into a central view. Intelligent PDU, UPS and other equipment readings can be integrated through protocols such as SNMP and Modbus, subject to device support and configuration.
Use those measurements to update the calculator inputs and examine whether usable capacity is reaching the racks that need it. The calculator is a manual planning tool; it does not connect directly to your devices or Quicklime.
Contact AKCP to discuss monitoring for your room, or explore Quicklime capacity planning for a broader view of rack space, power and cooling.
How much cooling does a 5 kW server rack need?
A rack consuming 5 kW produces approximately 5 kW of heat in steady operation, equivalent to 17,061 BTU/h or 1.42 refrigeration tons. Room cooling must also account for other heat sources and the fraction of rack heat removed through liquid.
Can I size server room cooling from floor area?
Floor area alone is insufficient. Two rooms of the same size can have very different IT loads. Start with electrical power and relevant room heat gains, then check airflow and equipment operating conditions.
Can I multiply IT power by PUE to get room cooling load?
Not reliably. PUE compares total facility energy with IT equipment energy. Some overhead is consumed or rejected outside the room, and cooling electricity is not the same as room thermal duty. Identify heat sources within the room boundary instead.
Does N+1 mean one more unit is enough for any failure?
N+1 adds one spare unit to the modeled duty group. Its effectiveness depends on independent capacity, controls, power and distribution. A shared failure can affect multiple units, so a unit count alone does not establish facility resilience or certify an availability tier.
Is summed server nameplate power a good input?
It can provide an initial conservative bound, but may be much higher than coincident operating demand. Use measured load or configuration-specific manufacturer estimates where available, and account for future growth explicitly.
How accurate is this calculator?
It provides a transparent steady-state estimate from the inputs you supply. It does not automatically model building thermal storage, weather, solar timing, workload diversity or complete psychrometric processes. Use the results to prepare a cooling review, then verify the design against project conditions and manufacturer data.
