Home » AKCP Blog » UPS Battery Recharge Time Calculator for Outage Recovery
When utility power returns, the UPS may resume normal operation before its batteries have recovered their previous backup capability. If another outage follows soon afterwards, the available runtime can be much shorter.
The AKCP UPS Battery Recharge Time Calculator estimates how long it takes to restore a selected state of charge, or SOC. It uses the current available to the bank and separates faster bulk charging from a slower taper stage. The result helps you examine a recovery window while keeping the charging assumptions visible.
Use the UPS battery recharge time calculator
Enter the battery or module Ah capacity, series and parallel counts, starting SOC and target SOC. The charger-current input is the total DC output current available at the complete bank voltage. It is not AC input current or current per battery string.
The tool can reduce available charger output by an entered availability percentage, subtract current diverted to shared DC loads, and cap the estimate at a known charge-current limit actively enforced by the charger or battery management system.
Only subtract loads fed by that same DC charging source. Do not subtract the UPS’s AC output-load current from battery charging amps. If the entered current is already a measured net battery current, use 100% availability and zero diverted current to avoid counting the reduction twice.
Estimate the time to restore a selected battery charge level using the current available to the battery and an allowance for charging taper.
Planning approximation, not a charger simulation. All starting values and battery-type presets are illustrative. Use measured charging data or manufacturer specifications for your system. This widget sends no inputs.
1. Battery bank
2. Current available for charging
If entering measured net current into the battery, use 100% availability and zero diverted current to avoid deducting the same load twice.
3. Charging assumptions
Approximate time to selected SOC
Bank configuration
Series adds voltage, not Ah. Parallel adds Ah. More parallel strings can lengthen recovery if total charging current stays the same.
Charging stages to your target
Two average-current stages; this is not a measured charging curve.
Recovery window
Enter a recovery window to compare.
Reaching a charge percentage does not establish the runtime available for a second outage. Check runtime at the actual load separately.
Time to common charge levels
| Target SOC | Charge to restore | Estimated time | Status |
Method, assumptions & references
Bank capacity C = battery Ah × parallel strings. Nominal bank voltage = battery V × series count. Starting/target SOC are fractions of the entered capacity basis. Nominal Wh is descriptive and is not the energy used to charge the bank.
Available charger current = charger DC amps × availability fraction − diverted DC load amps. If a known actively enforced battery-current limit is entered, net charging current is capped at that limit. A nonpositive available current cannot replenish a higher SOC target.
Let x be starting SOC, y target SOC and b bulk-to-taper transition, each expressed as a fraction. Bulk Ah to restore = C × max[0, min(y,b) − x]. Taper Ah to restore = C × max[0, y − max(x,b)]. Bulk hours = bulk Ah / (net bulk current × Ah efficiency). Taper hours = taper Ah / (net bulk current × taper-current fraction × Ah efficiency). Add the startup delay only when charge needs to be restored. Displayed completion times round up to whole minutes.
The presets are editable demonstration values: lead-acid uses 80% transition, 25% average taper current and 90% Ah efficiency; lithium uses 95%, 50% and 99%. These are not universal battery specifications. Replace them with data for the actual battery, charger, temperature and load. An average taper current for one SOC interval may not apply to another, so the milestone table is approximate.
The model does not simulate absorption-voltage control, individual-cell balancing, precharge after deep discharge, charger timer/termination rules, temperature restrictions, changing loads, recharge algorithms or unexpected BMS interruptions. At a 100% target, use the manufacturer's completion criteria rather than treating the estimate as proof of full charge. SOC also does not describe battery health.
Only known current limits are modeled. Do not increase charging current or alter battery wiring based on this calculator. The entered configuration and charging profile must be approved for the UPS/battery system. For critical recovery planning, validate against manufacturer recharge curves or a measured recharge test.
References: Victron: charging stages and recharge time · Eaton: lithium UPS charging limits.
Monitor UPS operating conditions, battery temperature and available charging data alongside your data center equipment. Explore AKCP monitoring solutions.
Account for the slower part of charging
Battery charging does not normally maintain the maximum bulk current all the way to completion. As the charger holds its absorption or charge voltage, current can decline. The time to the final target therefore depends on the battery and charging algorithm as well as the Ah that need to be returned.
The calculator uses an editable transition SOC and an average taper current expressed as a fraction of net bulk current. It also accepts Ah charge efficiency, meaning charge stored relative to charge entering the battery. This is different from UPS inverter efficiency.
Lead-acid and lithium presets are demonstration values. They are not approved charging profiles or specifications for every battery of those types. Replace them with manufacturer data or measurements from the actual recharge cycle.
Worked example from twenty percent charge
Use four 12 V, 100 Ah batteries in series with one parallel string. The bank is 48 V and 100 Ah. Connecting the four batteries in series does not make it a 400 Ah bank.
For this illustrative example, set net bulk current to 10 A, starting SOC to 20%, bulk transition to 80%, average taper current to 25% of bulk current and Ah charge efficiency to 90%. Set the startup delay to zero.
The bulk stage restores 60 Ah. At 10 A and 90% Ah efficiency, it takes 6 hours 40 minutes. The final 20 Ah use an average taper current of 2.5 A, taking about 8 hours 53 minutes 20 seconds. Total estimated time to the nominal 100% target is 15 hours 33 minutes 20 seconds, displayed as 15 hours 34 minutes after rounding up.
Target SOC | Estimated time from 20 percent |
80% | 6 hours 40 minutes |
90% | 11 hours 7 minutes |
95% | 13 hours 20 minutes |
100% | 15 hours 34 minutes |
The table applies the same average taper assumption to each interval. Real current changes through that stage, so these milestone times are approximate. A twelve-hour recovery window would accommodate the 90% target under this model, but not the nominal 100% target.
Check the effect of shared loads and larger banks
If only 8 A of a 10 A source is available and shared DC loads consume 2 A, the net bulk charging current is 6 A. Recovery takes longer than a calculation based on the full 10 A. If shared loads consume all the available output, the bank cannot gain charge under those conditions.
Adding parallel battery strings increases Ah capacity. With unchanged total charger current, the model takes longer to restore the same SOC change. Any expansion must also remain within approved UPS, charger and battery limits.
Validate recovery before relying on another outage
An indicated 90% charge does not prove that 90% of the original backup runtime is available. Runtime depends on load, battery condition and discharge behaviour. At a 100% target, use the manufacturer’s charge-completion criteria rather than treating a calculated time as proof of full charge.
Record charging current and battery conditions during a controlled recovery test. AKCP battery and UPS monitoring can support observation of suitable current, voltage and temperature measurements alongside available UPS charging status. Use measurements and interfaces appropriate to the system’s electrical ratings.
Can I use capacity divided by charger current for the whole recharge
It can approximate a constant-current interval, but it ignores charging taper, losses, shared loads and completion rules. Full recovery usually needs a more specific charging model.
Why does more battery capacity increase recharge time
A larger bank needs more charge restored for the same SOC change. Unless usable charging current also increases, recovery takes longer.
Does the calculator change charger settings
No. It uses entered assumptions only. The current-limit input represents a limit already enforced by the charging system.
Are the lithium preset values suitable for my UPS
Only if they match its documented charging behaviour. Battery management, temperature and balancing limits can alter the recharge profile.
