Home » AKCP Blog » UPS Efficiency and Cost Calculator for Comparing Electricity Use
A small difference in UPS efficiency can produce a measurable electricity saving when the system runs throughout the year. To calculate it properly, use the efficiency at the load and operating mode you expect, then work out how much input power is required to deliver that output.
The AKCP UPS Efficiency and Cost Calculator compares two systems or operating modes at the same protected load. It separates the electricity delivered to the equipment from UPS losses and can include the cooling electricity attributable to those losses.
Use the UPS efficiency and cost calculator
Enter the output load, annual operating hours and electricity tariff. The tool accepts real power directly or converts VA using the entered load power factor. Select a currency and enter all monetary values in that currency; selecting a different currency does not convert the tariff or investment.
Use AC-input-to-AC-output efficiency for normal-operation electricity costs. Battery-mode efficiency belongs in a runtime calculation. If UPS A and B have different capacities, check each efficiency curve at its corresponding loading percentage rather than comparing peak specifications.
Optional kW rating inputs show real-power loading and flag an excessive output load. They do not check the UPS’s VA limit or establish redundancy and protection suitability.
UPS Efficiency & Cost Calculator
Compare two UPS systems or operating modes at the same output load. Calculate electricity losses, heat output and potential annual savings.
Starting values are illustrative. Use efficiency at the actual load and operating mode, not a headline peak value. Calculations run in your browser; this widget sends no inputs.
1. Load & electricity price
2. Compare UPS efficiency
Use AC-input-to-AC-output efficiency for normal operation. Efficiency already includes losses within its measurement boundary; do not add those losses again.
Optional real-power rating checks
3. Optional cooling electricity
Includes only cooling attributable to UPS losses. IT-load cooling and other facility loads are excluded. Do not also multiply these results by PUE.
4. Optional investment & emissions
Annual electricity savings with UPS B
Annual overhead electricity cost
UPS losses plus optional cooling of those losses. Excludes electricity delivered to the protected load. Bars are scaled to the higher cost.
Investment comparison
Enter an extra investment to estimate simple payback.
Energy-cost comparison only. Maintenance, battery replacement, financing, tax, demand charges and differences in protection performance are excluded.
Emissions estimate
Enter a grid emissions factor to estimate the change.
Based on modeled electricity savings, not a full equipment life-cycle assessment.
Detailed comparison
| Measure | UPS A | UPS B | Difference |
How the calculator works
Efficiency η = output power / input power. For each system: input kW = output kW / η; loss kW = input kW − output kW. Loss heat is approximated as loss kW, with 1 kW = 3,412.142 BTU/h. For example, 100 kW output at 97% efficiency needs about 103.09 kW input and produces about 3.09 kW loss heat.
Annual UPS electricity = input kW × operating hours. Annual UPS loss electricity = loss kW × operating hours. If cooling is included: cooling kW = loss kW × cooled heat fraction / COP. Electricity cost = kWh × tariff. Total modeled cost includes UPS input electricity and only the optional cooling attributable to UPS losses.
Annual savings = cost A − cost B. Simple payback = extra investment / positive annual savings. Period savings = annual savings × years; net period savings subtract the extra investment once. Grid emissions savings = annual energy savings × the entered kg CO₂e/kWh factor. Changing currency does not convert the tariff or investment.
Assumes constant output load, fixed efficiency at that operating point, fixed tariff and fixed cooling COP. For a changing load profile, calculate separate periods using the matching efficiencies and sum their annual energy/costs. An average of efficiency percentages is not generally equivalent to energy-weighted efficiency.
The model excludes operation outside entered hours, separate standby/no-load losses, battery recharge events, battery-mode periods, demand charges and unrelated facility energy. Do not use battery-mode efficiency for annual normal-operation costs. Heat is an approximate operating-point loss calculation, not a replacement for manufacturer HVAC design data.
A higher-efficiency operating mode may have different transfer behavior, power conditioning and protection characteristics. Compare those requirements as well as energy costs. An optional kW rating check does not establish full UPS compatibility.
References: Schneider Electric: UPS efficiency · Eaton: efficiency and ownership costs.
Track power and UPS operating conditions alongside your data center monitoring. Explore AKCP monitoring solutions.
Calculate input power before calculating losses
UPS efficiency is output power divided by input power. At 100 kW output and 97% efficiency, input power is approximately 103.09 kW. The loss is about 3.09 kW.
Applying 3% directly to the 100 kW output would give 3 kW and understate the loss slightly. That distinction becomes material when the result is multiplied by thousands of operating hours.
Worked example comparing two UPS systems
These are illustrative operating points, not specifications for particular products. Use 100 kW output, 8,760 hours per year and USD 0.12 per kWh, with cooling excluded initially.
Measure | UPS A at 94 percent | UPS B at 97 percent |
Input power | 106.38 kW | 103.09 kW |
UPS loss and approximate heat | 6.38 kW | 3.09 kW |
Annual UPS input electricity | 931,914.89 kWh | 903,092.78 kWh |
Annual electricity cost | USD 111,829.79 | USD 108,371.13 |
Using unrounded values, UPS B saves approximately 28,822.11 kWh and USD 3,458.65 per year. Both systems deliver the same energy to the protected load, so the saving comes from the difference in losses.
An extra USD 10,000 investment would have a simple energy-cost payback of about 2.89 years. Over five years, gross electricity savings would be approximately USD 17,293.27, leaving USD 7,293.27 after subtracting that extra investment once. The calculation assumes unchanged load, tariff and efficiency.
Include cooling without counting it twice
If the UPS loss heat enters a conditioned space, removing it can require additional electricity. The optional cooling calculation uses the fraction of loss heat that needs cooling and the cooling system’s coefficient of performance, or COP.
With all loss heat cooled at COP 3, the example’s heat reduction saves about USD 1,152.88 per year in additional cooling electricity. Combined savings become approximately USD 4,611.54 per year. These figures exclude cooling of the IT load and unrelated facility energy.
Do not also multiply the result by a whole-site PUE factor. That would apply a broader overhead allowance after the specific cooling allowance has already been counted.
Use the comparison as part of a wider decision
The tool estimates electricity costs, rather than complete ownership costs. Battery replacements, maintenance, demand charges, installation costs outside the entered investment, financing and tax can change the investment decision. A different operating mode may also change transfer behaviour and power conditioning, which need a separate review.
For changing loads, calculate separate periods using the corresponding efficiencies and operating hours, then add their energy and costs. A simple average of efficiency percentages can give a misleading annual result.
Compare the assumptions with recorded power data. AKCP battery and UPS monitoring provides a route to monitoring suitable power and environmental measurements alongside available UPS operating information.
Does a three point efficiency increase mean three percent lower bills
Not necessarily. Electricity savings depend on the input-power difference at the same output load. The percentage reduction in losses differs from the reduction in total input energy.
Why does the calculator show negative savings
UPS B has a higher modeled electricity cost under the entered assumptions. Negative savings should be read as an increase in cost.
Is the payback result a complete financial assessment
No. It divides the extra investment by positive annual electricity savings. Other costs and the time value of money are excluded.
Can I calculate emissions savings
Yes, using an applicable grid or supplier emissions factor. The result covers modeled electricity use, not the equipment’s full life cycle.
