Home » AKCP Blog » Rack Power Calculator and PDU Capacity Planning | AKCP
Rack Power Calculator for PDU Capacity and A/B Failover Planning
A rack may have room for another server and still be close to its electrical limit. The problem often appears during maintenance or a power failure, when one PDU has to carry equipment that normally shares its load between two feeds.
The AKCP Rack Power and PDU Capacity Calculator helps you check that scenario before adding equipment. Enter the rack load, each feed’s electrical ratings and a growth allowance to estimate usable capacity, expansion headroom and the load on a surviving feed. You can also check measured phase currents and estimate rack heat output and electricity costs.
Rack power capacity is the load your power arrangement can support under the conditions you need it to survive. For a rack designed to continue operating after either feed fails, that means checking the full rack load against each feed individually.
Use the AKCP rack power calculator
Start with a measured peak load or a realistic estimate of the equipment’s simultaneous input power. Select single-phase or balanced three-phase power, then enter the PDU ratings and any lower upstream current limit.
For A/B power, enter both feeds separately. They can have different ratings. Set the normal load share and, where appropriate, an additional failover load allowance. The calculator applies your growth percentage before checking capacity.
The equipment list is useful when planning a new rack. Enter the quantity and AC input watts per complete device, including switches, storage and rack auxiliaries. Use the total-load option when you already have representative rack measurements.
Rack Power & PDU Capacity Calculator
Plan rack loads, check A/B feed capacity after a power failure, and estimate expansion headroom, cooling duty and electricity cost.
1. Rack equipment load
Use measured peak or expected simultaneous electrical input. Two 1,200 W power supplies do not mean a server consumes 2,400 W.
Each row uses AC input W per complete device. Include networking, storage and rack auxiliaries. Count each device once.
2. Feed configuration
Both feeds must independently carry the entire projected rack load after a failure.
Measured three-phase current check
Enter simultaneous RMS line currents from one three-phase PDU input. This snapshot is independent of the rack load model and is not scaled for growth or failover. It does not calculate watts from unbalanced currents.
Annual electricity and cost estimate
Capacity planning uses peak load. Energy uses average load during the entered hours, so a separate average input is provided.
How the calculation works
Single-phase feed capacity (VA) = voltage across load × line current
Balanced three-phase capacity (VA) = √3 × line-to-line voltage × current per line
Effective line-current rating = lower of PDU rating and entered upstream current limit
Nominal real capacity (W) = lower of electrical VA capacity × load PF and optional manufacturer real-power limit
Feed planning capacity = nominal real capacity × selected utilization ceiling
Projected rack load = base rack load × (1 + growth / 100)
A/B failover load on either surviving feed = projected load × (1 + failover allowance / 100)
A/B rack ceiling = minimum of: A planning capacity ÷ A normal share; B planning capacity ÷ B normal share; smaller feed planning capacity ÷ failover multiplier
Zero normal shares are omitted from the normal-operation ceiling calculation
Extra server count = floor[positive expansion headroom ÷ (server W × growth multiplier)]
Rack heat (BTU/h) = projected load (kW) × 3,412.142
Annual rack energy (kWh) = average rack kW × hours
Facility-attributed energy = rack energy × facility PUE
PDU capacity is expressed as real power at the entered load power factor. A PDU does not have a fixed load power factor of its own. A manufacturer kW limit may impose a separate ceiling; do not multiply that real-power limit by PF again. Lower limits are used without rounding before the calculation.
For three phase, enter line-to-line input voltage (for example, 400 V on a 400/230 V system), and input current per line. For a single-phase 208 V line-to-line load, select single phase. The three-phase capacity model assumes balanced loading and does not map outlet banks, delta branch currents, neutral current or harmonics.
The optional upstream current input must be a comparable per-line rating for this PDU's path. Shared upstream loads and shared UPS capacity require separate analysis. The selected utilization ceiling is applied after the lower current or real-power limit; if a nameplate already states a derated usable rating, entering an additional ceiling gives extra planning margin.
What the A/B check means
Adding the capacities of two feeds can overstate the rack load that can survive a failure. This calculator tests normal loading and then the complete projected rack load on each feed individually. Unequal feed ratings are supported; the smaller feed normally sets the failover ceiling.
The capacity result assumes all included devices can continue on either feed through suitable dual power supplies or a compatible transfer device. Single-corded equipment without transfer capability will lose power regardless of headroom. Independent power paths, transfer behavior, available UPS capacity and outlet-bank loading still need verification.
With identical feeds, a 50/50 split, an 80% planning ceiling and no extra failover allowance, each feed's normal projected load can reach 40% of its nominal capacity while preserving the selected ceiling after failover. A green capacity result is a pass of this mathematical model, not confirmation of end-to-end redundancy.
Using measured currents and rack power
The line-current check compares each measured line with the selected feed's effective current rating and utilization ceiling. Current deviation is 100 × maximum absolute difference from the three-line mean ÷ mean. All-zero readings give zero deviation. This indicator is not voltage unbalance and does not predict neutral heating.
Take readings during representative workload peaks and test failover under an approved operating procedure. A balanced total kW estimate can hide an overloaded line or outlet bank. The measured snapshot does not validate post-failure phase loading. Record phase and branch data during failover where available.
Use simultaneous A and B real-power readings to calculate the total rack load. Do not add a server's reported consumption again if it is already included in the PDU total. For VA inputs, changing PF changes the derived real load; W inputs remain real watts.
Calculation references and limitations
- Schneider Electric Electrical Installation Guide — single-phase and balanced three-phase real/apparent power relationships.
- Vertiv: How to avoid downtime with redundant rack PDUs — surviving-feed load and rack power redundancy.
Not evaluated: cable sizing, voltage drop, breaker coordination/trip curves, inrush, harmonics, neutral loading, outlet/branch limits, environmental derating, transfers or local code requirements. Minimum required rating results are arithmetic lower bounds, not selected breaker sizes. Equipment count does not check physical space, cooling capacity, connectors or installation limits. Validate the installation with manufacturer documentation and project engineering.
Turn rack power estimates into operating data
Compare your plan with measured rack power, temperature and available PDU/UPS telemetry. Explore AKCP monitoring for your data center.
Manual planning tool · Calculations run in your browser · No live sensor connection · All starting values are editable examples.
How much power does a server rack use
There is no single useful answer for every rack. Equipment type, workload, configuration and power-management settings all affect consumption. A lightly populated networking rack and a rack of compute servers need different assumptions.
For an existing rack, record power during representative workload peaks. One reading taken during a quiet period is a poor basis for deciding whether another server will fit. For a planned deployment, use vendor configuration data, measurements from comparable equipment or an agreed design load.
Be careful with redundant power supplies. A server with two 1,200 W PSUs does not necessarily consume 2,400 W. Those labels describe power supply capacity, and may refer to DC output. The calculator’s equipment rows need the expected AC input power of the complete device.
When measuring an A/B rack, add simultaneous real-power readings from the two PDUs. If those readings already include all the servers, do not add the server-reported consumption again.
Calculate PDU capacity from voltage current and power factor
Watts describe real power. Volt-amperes describe apparent power. Power factor relates the two:
W = VA × power factor
At a power factor of 0.95, a 5 kW rack represents approximately 5.26 kVA. Lower power factor means more apparent power and current for the same real load.
The basic capacity equations are:
- Single phase: VA = voltage across the load × line current.
- Balanced three phase: VA = √3 × line-to-line voltage × current per line.
For a 400/230 V three-phase input, enter 400 V. For a single-phase load supplied at 208 V between two lines, select single phase and enter 208 V. Use the PDU’s input current rating per line, rather than adding outlet-bank ratings. These relationships are explained in the Schneider Electric Electrical Installation Guide.
The calculator uses the lower of the PDU input current rating and an entered upstream current limit. You can also enter a separate manufacturer real-power ceiling. This helps account for a constraint that a simple voltage-times-current calculation would miss.
Why two PDUs do not double redundant rack capacity
If a rack normally draws 3 kW from Feed A and 3 kW from Feed B, the surviving feed may need to supply the full 6 kW when the other feed is lost. Adding the two feed capacities would overstate the load that can survive that failure.
The calculator checks the normal split and both failure cases. Unequal feeds matter: a rack must remain within Feed A’s limits when B is unavailable, and within Feed B’s limits when A is unavailable. Vertiv’s guidance on redundant rack PDUs explains why surviving-feed loading is central to redundancy.
This assumes the equipment can operate from either feed. Single-corded devices need an appropriate transfer arrangement if they must survive the loss of their source. Independent upstream paths, available UPS capacity and transfer behavior also need verification.
Worked example for a 5 kW rack
The calculator starts with an illustrative rack using these values:
| Input | Value |
| Base rack load | 5 kW |
| Future growth | 20% |
| Feed A and Feed B | Each 208 V three phase and 30 A per line |
| Aggregate load power factor | 0.95 |
| Planning utilization ceiling | 80% on each feed |
| Normal load share | 50% on A and 50% on B |
| Extra failover load allowance | 0% |
Each feed has approximately 10.81 kVA of apparent input capacity. At the entered load power factor, its nominal real-power capacity is about 10.27 kW. Applying the selected 80% planning ceiling gives 8.21 kW per feed.
The projected rack load is 5 × 1.20 = 6 kW. During normal operation, each feed carries 3 kW. After either feed fails, the survivor carries the full 6 kW, which remains within the modeled 8.21 kW planning ceiling.
Expansion headroom is approximately 2.21 kW beyond the entered growth allowance. If an additional server is expected to draw 500 W, the same 20% growth allowance makes its planning load 600 W. The calculator therefore shows room for three additional servers on electrical capacity alone. Rack space, cooling, connectors and outlet-bank limits may reduce that number.
Choose a planning ceiling that matches your installation
The calculator’s 80% starting value is an editable planning assumption. It is not a universal rule for every circuit, PDU or jurisdiction.
Read the manufacturer’s documentation carefully. Some ratings already describe usable continuous current under specified conditions. Applying a further planning percentage to that rating leaves additional reserve, which should be an intentional choice.
For identical A/B feeds with a 50/50 split and no extra failover allowance, an 80% ceiling on the surviving feed corresponds to 40% of nominal capacity on each feed during normal operation. Those percentages describe different operating conditions; they should not be treated as interchangeable limits.
Check individual phases as well as total rack power
A three-phase rack can appear to have spare capacity while one input line is carrying too much current. The main capacity model assumes balanced loading, so use the optional measured-current check to examine simultaneous L1, L2 and L3 readings from a PDU input.
The tool compares each line with the effective input current rating and your selected planning ceiling. It also reports the maximum current deviation from the three-line mean against an editable alert threshold.
This is a separate measurement snapshot. It does not scale the readings for growth or predict how current will redistribute after failover. Check branch and outlet-bank loading separately, and obtain representative post-failure readings through an approved test procedure where needed.
Turn rack power into a cooling estimate
Nearly all the electrical input to IT equipment ultimately becomes heat. The example’s projected 6 kW rack therefore represents approximately 6 kW of thermal load, or 20,473 BTU/h. The conversion is about 3,412 BTU/h per kW; Schneider Electric documents the watts-to-BTU/h relationship.
For liquid-cooled equipment, some heat is transferred directly into coolant. Total rack heat should therefore be separated into the portions handled by the liquid and air cooling systems. The calculator’s heat result does not establish that split.
The occupied-U input also gives projected kW per occupied rack unit. Treat this as a density indicator, rather than proof that airflow or cooling capacity is sufficient.
Use average load to estimate electricity costs
Capacity planning needs a load that represents demanding operating conditions. Electricity estimates need average power over time. Using peak rack power for every hour of the year can overstate consumption.
The calculator provides a separate average-load input. At 3.5 kW for 8,760 hours, annual rack electricity is 30,660 kWh. At USD 0.12/kWh, the modeled cost is USD 3,679.20.
Entering a facility PUE of 1.4 gives 42,924 kWh and USD 5,150.88 of facility-attributed electricity. This allocates infrastructure overhead to the rack using a facility ratio. It does not mean the rack produces 40% more heat.
These figures assume constant average load, tariff and PUE. They exclude demand charges, taxes and equipment costs. Use metered energy and appropriate facility data when assessing actual expenditure.
Compare the plan with AKCP monitoring data
The calculator gives you a planning baseline. Monitoring shows how closely the operating rack follows it.
Quicklime DCIM monitoring can bring compatible PDU and UPS data into view alongside AKCP environmental measurements. Supported SNMP and Modbus integrations provide access to measurements exposed by the connected equipment. Available points depend on the model, firmware and configuration.
Compare rack power trends with inlet temperatures and operating events. Review both feeds together, then investigate whether a capacity issue comes from rising total load, uneven distribution or a lower limit elsewhere in the power path. AKCP’s data center capacity planning and battery and UPS monitoring solutions provide more information on these monitoring options.
Before installing more equipment, check the projected rack load against normal and failure conditions, then verify the phase, branch, cooling and upstream constraints that the calculation cannot establish.
How do I calculate rack power consumption
Add the expected simultaneous AC input watts of the equipment, or use representative measured rack power. For an A/B rack, add simultaneous real-power readings from both PDUs and avoid counting the same equipment twice.
Can I add the capacities of both rack PDUs
For full A/B failover, each feed must independently support the complete projected rack load. Adding their capacities describes combined capacity during normal operation, not the load that can survive either feed failing.
Should I enter watts or volt amperes
Enter whichever measurement you have. The calculator accepts W, kW, VA and kVA, using the entered load power factor to convert between real and apparent power.
Does the additional server count include future growth
Yes. The calculator applies growth to the existing rack load and to each added server’s input watts before calculating the count. The result only evaluates electrical headroom.
Does a passing result prove that my rack is redundant
No. It means the entered load fits the modeled capacity limits. Device power arrangements, independent upstream paths, transfer behavior, phase distribution and branch limits need separate verification.
Does the phase check calculate power from unbalanced currents
No. It checks measured RMS line currents against current limits and reports their deviation from the mean. It does not derive watts or predict post-failure loading.
Is the 80 percent ceiling mandatory
It is an editable planning value in this tool. Select a ceiling appropriate to the documented usable equipment ratings and the requirements of your installation.
Does the calculator connect directly to Quicklime or sensors
No. It runs manually in your browser. Enter measurements from your monitoring system to compare the operating data with the planning model.
Need help monitoring your rack power and environmental conditions? Contact AKCP to discuss your equipment and monitoring requirements.
