Home » AKCP Blog » How Server Rack Airflow Solutions Improve Energy Efficiency
The more power a server consumes, the more cooling it needs. This is why air conditioning systems are the biggest consumer of energy in many data centers. When heat builds up because the cooling system is not capable of keeping up hotspots result which can cause servers to malfunction. It is therefore important to ensure that server rack airflow is capable of carrying away the heat generated by the server. This article will look at solutions to improve energy efficiency through improving server rack airflow.
Server Racks and Network Cabinet Designs
A standard design for a server rack is a four-post frame to which side panels, and front and rear doors are attached. The unvented side panels are usually removable. The front door can be customized into various designs such as perforated for ventilation or glass. This is also an option for the rear door.
The front door of the rack could be installed with an RFID lock handle. It is also recommended to install monitoring devices within the server room environment. They should be deployed in both the room and within the racks to monitor the thermal conditions of the server room.
Custom Server Racks
In today’s industry, data centers can now customize their server racks and make alterations that may fit the facility design, r something that could be more practical to fit the cooling strategy in use. Customization ranges from including liquid-cooled panel doors, built-in air conditioning units, overhead metal returns, or the use of a cold or hot-aisle arrangement. The standard rack has an IP rating of 20 but through customization, it can be increased to IP54 or higher depends on the requirement of the data center.
Rack-Level Air Flow Strategy
All IT equipment must have a proper supply of cool air coming in the front of the rack. This strategy ensures that
the air passes through all equipment within the rack. Any gaps should be sealed as they serve as an opportunity for the air to bypass the servers, wasting cooling energy. This is the purpose of front blanking panels. A blanking panel is a piece of plastic or metal that goes into an empty spot in the rack to prevent cool air to pass through it or hot air to slip back inside the rack.
Server Rack Air Flow Checklist
However small an open space or unsealed space is, it can still reduce the server rack airflow efficiency. Managing the server rack airflow mainly focuses on getting the air past all the equipment then straight to the exhaust channel. Small openings, or missing blanking panels are not always a problem if air pressures and airflow management is done correctly. Here are few recommendations to consider:
- Front Door Design
Rack front doors, as mentioned earlier, can be customized depends on the requirement of the data center. However, it is important to take note that the front door also affects the design of the cooling system and the thermal dynamics of the rack.
The door provides the access to the equipment within the rack. For security, access can be connected to the building access control system or it can have its locally installed security system.
- Rack Height Spacing
It is important to use a suitable sized and fixed server cabinet. This ensures that each available ‘U’ is used or covered with a blanking plate and this is to prevent to have any air gaps. The blanking plates, of course, should be in a suitable size as well. The more blanking plates are used the more the gap and server rack airflow efficiency issues are compounded.
- Rack Equipment Layout
Laying out equipment in the rack requires the utmost care. Take time to know which equipment generates the most heat and where to place them. One thing that should be on top consideration is the UPS systems. If the batteries are valve-regulated lead-acid (VRLA) type they require 20-25°C ambient temperature.
- Side Panels and Rails
Bypass airflow happens when the cooled air is returned to the air cooling unit without passing the IT equipment. Operators should make sure that the spaces between the side rails, the equipment they are supporting, and the backside panels are sealed. As these spaces provide an opportunity for bypass airflow.
- Top of Rack
Ensuring a good airflow around the top fan tray of the rack is important to avoid any potential airflow infringement that could reduce the overall cooling effect.
- Rear Doors
Rear doors are usually overlooked as it is only regarded as access to terminals and power connections. But in truth, this area is where the hot air is channeled and exhausted for return to the cooling unit. Mixing hot air and cold air must be avoided at all times to ensure optimal efficiency. Rear doors must be as fitted as everything else to ensure the exhausted hot air’s path back to the cooling unit.
- Temperature Monitoring
Installing a temperature monitoring system within the server rack is the best strategy. Deploy the temperature sensors at three levels, as per ASHRAE, from the top, middle, and bottom sections at the front and rear of the racks. Choose a suitable monitoring system that offers 24/7 real-time monitoring and alarm notifications. Monitoring solutions could also be expandable or include other aspects like smoke and water detection.
Server Room Airflow Monitoring with AKCP
Server Rack Airflow and Thermal Mapping for IT Cabinets
Differential Temperature (△T)
Differential Pressure (△D)
Additional Server Room Monitoring from AKCP
Water Detection
Ideal for detecting water leaks in hard-to-see areas, such as under-raised floors and false ceilings. The Locate Rope Water sensor will give you a precise location of the water leak so you can respond promptly to protect your enterprise resources from water damage.
This sensor comes fully assembled and includes the rope portion that is the water sensing cable, the non-sensing cable, and the main sensing module. The sensing cable can be pre-ordered from a 10-foot minimum to any custom run length of up to 160 feet. The non-sensing cable comes in a standard 20-foot run length.
The specific location of water along the rope can be used to trigger alerts like e-mail, SMS, phone calls, and SNMP traps. The sensor has its own SNMP OID so that it can be monitored over the network using any Network Management System.
Smoke Detector
Fire detection in its early stage is very important. There are many smart fire detectors in the market now that can adapt or cope up with various types and layouts of server rooms and provides accurate and very early warning of fire.
AKCP has designed a smoke sensor specifically for use with its securityProbe product line. These smoke detectors are easy to install and configure and can be used in conjunction with all other AKCP alerting and monitoring features.
For server room, monitoring inquiries message us at sa***@ak**.com
https://www.upsite.com/blog/rack-airflow-management-how-sealing-gaps-leads-to-energy-savings/
