Home » AKCP Blog » UPS Load and Runtime Calculator | AKCP
UPS Load and Runtime Calculator for Backup Power Planning
A UPS runtime estimate answers a practical question: how long can the batteries support the equipment if utility power fails? The answer depends on the actual load, the battery bank and the conditions under which it is operating. The VA number on the UPS nameplate does not tell you its backup time.
The AKCP UPS Load and Runtime Calculator helps you check output capacity and estimate battery endurance. You can allow for future load growth, compare different load levels and see whether the estimate meets your required runtime.
Use the UPS load and runtime calculator
Enter the load you expect during an outage, rather than adding every power supply nameplate at its maximum rating. Measured power is a better starting point. Include the network, storage and management equipment that must remain available alongside the servers.
The calculator accepts W, kW, VA or kVA. When working with apparent power, it uses load power factor to calculate real power. It also checks the UPS output ratings in both W and VA. Exceeding either rating triggers an overload warning and suppresses the runtime result.
UPS Load & Runtime Calculator
Check UPS capacity, allow for growth, and estimate how long your batteries can support the load.
Illustrative starting values. Replace them with measured load and your UPS specifications. Calculations run in your browser; this widget sends no data.
1. Load & UPS capacity
2. Runtime calculation
Use the rating of one battery or module. Series adds voltage; parallel strings add Ah capacity.
Lead-acid rate assumptions
Additional battery-side power loss
Enter at least two points for the same UPS, battery configuration, temperature and battery condition. One line per point: load in W, runtime in minutes. Placeholder values are examples, not manufacturer data.
Interpolates between adjacent points on a log-log scale. No extrapolation. Battery factors above do not apply to this mode.Estimated runtime at planned load
Capacity planning
Minimum output ratings at your chosen planning ceiling:
—Both W and VA ratings must be satisfied. These figures do not size batteries or establish redundancy.
What if the load changes?
| Load | W | Runtime | Check |
| Enter valid inputs. | |||
How this calculator works
Real power: W = VA × load power factor. Planned load = connected load × (1 + growth / 100). Minimum UPS ratings = planned W and VA divided by the planning ceiling fraction.
Battery energy E = battery V × battery Ah × series count × parallel count. Battery-side power P = planned W / efficiency + fixed DC overhead. Runtime (minutes) = 60 × E × health × usable window × rate factor / P. Percentage factors are converted to fractions.
For lead-acid, current per string I = P / (battery V × series count × parallel count). Rate factor = min[1, (Ah / rating hours / I)^(Peukert exponent − 1)]. This approximation reduces available energy at high discharge rates and caps low-rate capacity at nameplate energy. It uses constant nominal voltage; it does not simulate voltage sag or changing discharge current.
Runtime-data mode uses piecewise log-log interpolation of the points you enter. It does not add efficiency or aging adjustments, and returns no estimate outside the supplied load range. The headline runtime rounds down to whole minutes; target checks use the unrounded estimate.
Neither method models temperature, individual weak cells, inverter cutoff, BMS current limits, transient loads or recharge time. Check manufacturer discharge/runtime curves and validate critical loads with a controlled test. Bank counts describe an existing approved configuration; they are not instructions to alter battery wiring.
References: Eaton UPS runtime curves · Battery capacity and Peukert's law
Track actual load, battery condition and runtime trends alongside your data center monitoring. Explore AKCP monitoring solutions.
Understand watts and VA before comparing capacity
Watts describe real power consumed by the load. VA describes apparent power. A 1,000 W load with a power factor of 0.8 represents 1,250 VA, so both figures matter when choosing a UPS.
The planning load ceiling lets you leave output headroom. Its 80% starting value is an editable planning choice, not a universal operating rule. Future load growth is applied before the capacity and runtime checks.
Choose the runtime method that matches your data
Battery specifications mode estimates runtime from nominal voltage, Ah capacity, series and parallel counts, battery-mode efficiency, remaining capacity and the usable discharge window. The lead-acid option adds an approximate discharge-rate adjustment using an editable Peukert exponent and Ah rating period.
These inputs have different meanings. Battery health describes capacity remaining relative to new. The usable discharge window describes the portion of charge available between the starting and reserved state of charge. Battery-mode efficiency describes conversion from battery power to the protected load. Counting the same allowance twice can make the result unnecessarily conservative.
Manufacturer or tested runtime-data mode uses load and runtime points for a particular configuration. It interpolates between adjacent points and does not estimate outside the supplied load range. Use points from the same UPS, battery configuration and operating conditions; the battery factors from the other mode are not applied again.
Worked example using the energy only model
Consider this illustrative battery bank. Select the energy-only option with no discharge-rate correction, zero load growth and zero additional DC overhead.
Input | Value |
Real load | 600 W |
Battery voltage and capacity | 12 V and 100 Ah per battery |
Configuration | Four batteries in series and one string |
Battery-mode efficiency | 90% |
Remaining capacity | 80% |
Usable discharge window | 90% |
The nominal bank energy is 4,800 Wh. Applying the three percentage factors gives 3,110.4 Wh available to the AC load under this simplified model. At 600 W, the calculation gives 311.04 minutes; the headline display rounds down to 5 hours 11 minutes.
This is a demonstration of the arithmetic, not a prediction for a specific UPS. Lead-acid discharge-rate effects, voltage sag and inverter cutoff can reduce the result. Check the manufacturer’s runtime curve before relying on it for a shutdown or generator-transfer plan.
Use the result to improve your backup plan
Compare the 50%, 75%, 100% and 125% load scenarios to see how load changes affect the estimate. Check the target runtime against the time needed for generator transfer or an orderly shutdown, including reserve. Download the summary so that the assumptions remain attached to the result.
For an operating site, compare the plan with recorded load and UPS runtime readings. Battery temperature and fault history provide useful context when the runtime estimate changes. Explore AKCP battery and UPS monitoring for ways to combine suitable AKCP sensors with available UPS data through supported SNMP or Modbus integrations.
Can I calculate runtime from the UPS VA rating alone
No. The VA rating limits output capacity. Runtime also depends on real load, stored battery energy, discharge behaviour and system limits.
Should I use mains mode efficiency
Use battery-mode efficiency for a battery runtime estimate. Normal AC operation may have a different efficiency.
Does adding a second battery string double runtime
It increases nominal energy, but actual runtime depends on discharge rate and the UPS configuration. Only use configurations approved by the manufacturer.
Is the calculated runtime guaranteed
No. It is a planning estimate. Model-specific data and a controlled test are needed to validate critical backup requirements.
