Home » AKCP Blog » Sensor Controlled Relay controls the electrical power to devices over Internet.
Bangkok, Thailand. Dec 6, 2002
The Sensor Controlled Relay plugs into the sensorProbe and controls the electrical power to devices over the Internet.
The Sensor Controlled Relay is designed to control the power to devices over Internet. It is the one of series of power electronics products from AKCP. With easy configuration & integration with sensorProbe product series, the Sensor Controlled Relay defines a new era in energy management.
About Sensor Controlled Relay
The Sensor Controlled Relay monitors the power & load and gives a control signal which is picked by the sensorProbe. It provides 1 high-power SPDT 5V including Metal Oxide Varistor (MOVs) and Snubber circuit to protect the open contact of the relays from the high voltage spikes or noise transients.
It operates from a single +5 V DC Power Supply from the sensorProbe. The operating voltage range is 110 V AC to 220 V AC and can carry current up to 16A with low power consumption. It has an operating temperature range of -40°C to 85°C and weighs only 250 grams.
Areas of application
Sensor Controlled Relay can be used for a variety of applications like Power Switching, On/Off Control, Activate Alarms, Process Control, Energy Management Systems etc.
Cost of Sensor Controlled Relay
Price: $165.00 with cable to connect to sensorProbe.
