Home » Customer Story » AKCP Monitors Simon Fraser University Data Center
AKCP, the world’s oldest and largest supplier of networked wired and wireless sensor solutions monitors the Simon Fraser University Data Center.
The Simon Fraser University Data Center houses 175 racks and the worlds 50th largest super computer named Cedar. AKCP have supplied a monitoring system consisting of sensorProbeX+ base units, spot and rope water sensors, smoke detectors, temperature and humidity sensors.
Such compute power requires a large cooling system. AKCP rope and spot water sensors were installed in the mechanical room which houses the chilled water plant equipment. Spot water sensors were placed in strategic locations such as drip trays. Rope water sensors were laid out along the lengths of pipes and perimeters of enclosures.
In the main data center hall rope water sensors were installed along the lengths of aisles. Positioned underneath the door of each rack. The data center employs rear door heat exchanger cooling systems from Coolcentric. These cooling systems contain glycol, which the AKCP rope water sensor can also detect. The IT staff are immediately notified of any leaks from the rear door heat exchangers that may occur.
AKCP wired and Wireless Tunnel monitoring system is available now. Contact sa***@ak**.com for more details.
