Home » AKCP Blog » Function And Reasons to Install Environmental Monitoring System
Basic Functions of Data Center Monitoring Systems
Datacenter environmental monitoring systems enable you to centrally monitor and control your data centers environmental conditions. You may connect to, gather data from, and configure devices using HTTP, MQTT/S, SNMP, and other IP-based network protocols. Datacenter environmental monitoring systems may perform a wide range of tasks, and with so many data monitoring solutions to select from, it’s crucial to understand what features you should be looking for. Here’s a quick rundown of the features we think are essential or beneficial in a data center monitoring system.
Real-Time Monitoring
Downtime in your data center may be extremely costly, as well as damaging to your company’s brand and client retention. As a result, the ability to monitor performance in real-time is critical. You must track your data center operations and systems in the physical computer room, as well as monitor network devices, to verify that the network infrastructure is healthy and functioning, and to guarantee that important systems and services stay online. Managing the infrastructure well from mechanical equipment to electrical systems is a must to maintain data center uptime. This may be accomplished without missing a beat or losing a single minute of time thanks to a real-time monitoring support.
Analytics And Reporting
With so much data coming across your network, manually tracking and interpreting, and analyzing each indicator may become complex and time-consuming. Data monitoring software platforms with analytics and reporting capabilities can help with this, allowing you to swiftly evaluate data and generate alerts when anything out of the ordinary occurs. Performance data may also be graphed using analytics software, making it easier to understand. Datacenter infrastructure management software (DCIM) is also widely used to manage the complete data center network, and infrastructure and monitor environmental conditions.
Workflow
It’s a multi-step procedure to add additional servers or hardware to your data center, and it might affect multiple data center components. A data center monitoring system should be able to manage the server installation process, ensuring that all essential procedures are conducted and finished before any new software or hardware is made available to the public.
Change Management And Asset Configuration
It might be difficult to keep track of changes to your data center’s assets. After all, if one of your servers goes down, you need to figure out what’s causing it as soon as possible. This implies you’ll need to find the problem as fast as possible and obtain insight into its setup, which asset configuration skills may help you with. Change management utilities are also useful in a data center monitoring system because they allow you to watch systems that may have an influence on network performance and monitor infrastructure additions and configuration changes. DCIM software packages are also a useful tool for this type of capacity planning, asset tracking, and management.
Capacity Forecasting
One of the numerous advantages of data center monitoring systems is that they enable capacity planning. Data monitoring solutions may help you maximize resource utilization, such as cooling and power, and make better-educated decisions about increasing data center resources by giving you access to previous data and proactively evaluating patterns.
Integrations
You’re probably employing additional enterprise-grade IT solutions if you’re using a data center monitoring system. As a result, it’s critical that you pick a data center monitoring system that can readily interface with a variety of different technologies. Modeling tools, asset management tools, change management tools, and other third-party solutions may all be integrated to help you account for a variety of difficulties more readily.
Reasons Why Data Centers Need Monitoring System
Remote Controllability
Push And Instant Notification
The environmental monitoring system not only gathers data on environmental factors, but also alerts users to changes in those parameters, as well as earthquakes, fires, water leaks, and unlawful entry.Savings
Productivity Growth
Security
Temperature, humidity, and airflow are only a few characteristics the environmental monitoring system monitors. At the same time, equipment such as motion sensors, water leakage sensors, and smoke sensors allow control of circumstances such as illegal entry, theft, installation faults, power outages, fire, and earthquakes.Real-Time Data Collection and Environmental Monitoring Solutions
AKCPro Server
sensorProbeX+
Intelligent Sensors
sensorProbeX+ is compatible with all AKCP Intelligent sensors, making it an extremely versatile and cost-effective monitoring solution. From the data center to remote sites, industrial controls have you covered.
Environmental Monitoring Sensors
Wherever monitoring of environmental conditions is important to your daily operations and health of equipment, deploy sensors to monitor temperature, humidity, airflow, and water leaks.
Security Sensors
RFID Access control swing handle cabinet locks, door contacts, and motion detectors will keep you in tune with the security situation at your sites down to cabinet level. Control who can access and when with RFID access control, centrally managed and monitored through AKCPro Server.
hanwell.com/news/environmental-monitoring-and-control-systems/
